Old 02-16-2009, 08:36 AM
chevyguy10 chevyguy10 is offline
coolant loss
I am losing coolant from my 97 Lumina. It has about 120,000 miles on it. I don't see any on the driveway or signs of coolant on the radiator hoses or anywhere under the hood. When I had a water pump go out on vacation last year, the mechanic said the intake manifold was leaking. Could this be the problem.
Old 02-16-2009, 11:51 AM
Forscythe87 Forscythe87 is offline
Re: coolant loss
I had the same symptoms and it turned out to my my lower intake. Does your oil look like a milk shake, or is your coolant resevoir nasty? It doesnt always happen this way but mine did.
1998 Chevy Lumina LS 3.1L 126K Miles
Old 02-16-2009, 11:58 AM
Re: coolant loss
No, my oil looks OK, a little dirty but not foamy and the coolant reservoir looks clean. I'm not sure what lower intake is, is that part of your intake manifold. I was checking the exhaust to see if it looked different but couldn't detect anything. Seems like it has to be burning it if it's not leaking out on the ground.
Old 02-16-2009, 09:10 PM
jfitzsi1 jfitzsi1 is offline
Re: coolant loss
Check for leaks between the power steering pump and the base of the intake manifold. Intake manifold gasket on your car is probably the cause, one way or another.
Old 02-17-2009, 12:17 AM
discnik discnik is offline
Re: coolant loss
If it turns out to be the LIM gasket(More than likely), be sure to use either the Dorman or FelPro upgrade set. The Dorman comes with new manifold bolts, valve cover gaskets, metal w/ rubber intake gaskets, and other items for the job.
Old 02-17-2009, 07:00 AM
Re: coolant loss
Thanks for the replies. I will check into the gasket availability. I guess this is a common problem with this engine from some of the comments I have gotten.
Old 02-19-2009, 01:24 AM
Bearwulf's Avatar
Bearwulf Bearwulf is offline
Re: coolant loss
Yes VERY common. Usually happens before 100,000 miles.
Bearwulf, the "howling Grizzly" of the north.
MONOTONY is the worst driving hazard, so SHUT-UP when I'm driving.
97-Lumina LS
1891Argentine 7.65 with scope!
Old 02-23-2009, 10:29 AM
Re: coolant loss
I bought gasket set for lower intake manifold. The lower manifold instructions say no gasket adhesive required but i'm not sure about the upper manifold. Does it need some kind of sealant.
Old 02-24-2009, 03:23 PM
ChrisinVT ChrisinVT is offline
Re: coolant loss
Is this a problem with the 3100 and 3.1? I know there isn't too much of a difference between the two, but I figured I'd ask the question anyway.
www.gmwbody.com
The NEW GM W-Body Forum!
Chevy, Buick, Pontiac, Oldsmobile
Old 02-25-2009, 07:51 PM
Re: coolant loss
Yes, it is.
Old 02-27-2009, 04:35 AM
manicmechanix manicmechanix is offline
Re: coolant loss
Don't put any sealant or adhesive on the upper manifold. It isn't necessary. It isn't necessary on any of the gaskets on this application. Just put the RTV at the engine end seals.
The problem is mostly on '95 (93?)-'03 3100 and 3400. The 3.1 has a different intake manifold, and I'm not sure if the lower gasket is different but I haven't heard of them having the problem. the 3100 with the newer style manifold came out around '93. In '95, they swirtched to Dex-cool which seemed to make the gasket problem more common.
Old 03-09-2009, 11:11 AM
Re: coolant loss
I changed the lower gasket last Thursday and Friday, quite a job but it seems to have cured the problem. On another subject, does a 97 Lumina have a diagnostic port where you can hook up an analyzer. I have a Haynes manual but it doesn't mention it in there.
Old 03-10-2009, 07:21 PM
Re: coolant loss
Yes it's below the steering wheel under the dash.
Old 03-11-2009, 06:38 AM
Re: coolant loss
Thanks, I was thinking of getting an analyzer but don't even know what they cost. Do you know if there's one out there that an amateur mechanic can afford.
Old 03-11-2009, 10:09 AM
Re: coolant loss
There's the Innova Equus scanner. That's what I have. I think they are the best scanner for the price.There's several models. They run from between $90-150 if you look around. They have some Equus models that are more expensive, but you don't really get much more for the extra cost. if you're looking for a basic model the 3100, I think it is, will get you by, but for a few dollars more I went with the 3130, which if you look around online you can get it for under $150. What I'd really like to have is a GM Tech2 , but they can run in the couple thousand dollars . I'd really like to have a fuel injector tester kit and an injector cleaning kit too..
