Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 02-16-2009, 08:01 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
99 Olds 88 will not start.
I was working on a 99 olds 88, that wouldn't start, had spark, would crank over fine (had to jump start it though because battery was dead), NO FUEL PRESSURE - So after doing some searching, I was lead to the GROUND BUSS, I pulled the ground buss out but there was no corrosion as suspected and no bad wires coming off the ground buss, so i put it back in and turn the key on and I could hear the FUEL PUMP kick on and the car started right up. Also when this happened the Power Windows did not work and this help lead to the ground Buss thing, anyways what do you think could have been the problem with the GROUND BUSS?
Thanks
Joe
[email protected]
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 02-17-2009, 03:47 PM
maxwedge maxwedge is offline
A990 racer
Re: 99 Olds 88 will not start.
You missed something in the ground circuit, the power windows is the clue, look around again.
