Followup to 2000 GTP starting issues
Drove my 2000 GTP Saturday night on a short run...lots of condensation in the air as I had to keep the wipers going.
Sunday the key fob would not open any of the doors. I entered with the ign key in the drivers door and made the mistake of inserting the key into the ignition where I confirmed everything was dead. The mistake was because I had a full complement of tools in the trunk...but my key was now stuck in the ignition! Luckily, the "ski door" was unlocked in the rear seat and I was able to retrieve what I needed. Had 12vdc between the battery terminals, but zero volts to the B+ wire above the fusebox on the accessory drive end of the engine. Turned out the B+ ring-terminal had developed white corrosion on the flat which developed into insulating material. There was no outward sign from the red protective boot. I scratched & chipped the ring-terminal clean with a screwdriver and reinstalled with immediate improvement. I suspect this may have been my problem with some recent no-starts, mostly hot-starts after filling the tank with fuel, and the 2nd try always was successful...will have to continue to monitor. I have seen this same issue with another W-car (L36 Buick Regal), and my own S-10 had it bad enough to eat completely thru the B+ wire! I believe GM has eliminated use of side-terminal batteries and gone back to the old-style top-post batteries.
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
Re: Followup to 2000 GTP starting issues
Actually...the battery terminal is still the only part on the car that's not metric. 5/16" hex and 3/8" x 16 tpi thread.
You are correct that the thread goes into a lead (Pb) pocket...so there isn't a lot of room for error on the side of too tight. I had the complete chunk of battery lug fall out on my 1-year old Trailblazer with the B+ ring-terminal still attached. ![]() And I have heard many reports of same talking to people I know. I think the top-post leaves much less variation in what happens in the field. The new-style battery lugs appear much superior to the old-style junk where the nut galls directly into the split terminal.
