Old 02-15-2009, 05:10 PM
2000GTPgirl 2000GTPgirl is offline
Exclamation GTP Transmission Overheating?
I have a question cause for some reason it wont let me post a thread on here my 2000 GTP superchrged the transmission keeps overheating to like 199 i put coolant and tranny fluid in it but it still overheats. what temp is it normally suppose to run at and why would it do this
Old 02-15-2009, 05:18 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: GTP Transmission Overheating?
Welcome to AF.
Your post has been moved to its own thread.
It would help to post your mileage. Technically, 199 degrees is not overheating. What are your symptoms other than suspected overheating. How does it shift, etc.
Timeslip 08/12/06
AF Community Guidelines
Old 02-15-2009, 07:20 PM
CrazyHorst CrazyHorst is offline
Right, trans temp less than 150C = 302F is OK. With all else normal/functioning one has to work pretty hard to get it to that bogey. I too am interested in how the diagnosis was arrived at.
The trans will attempt to protect itself under such conditions by shifting harder to reduce internal heating (normal slipping) of the clutch packs...the line pressure is boosted in such occasions.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 02-15-2009, 07:55 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
You put coolant and tranny fluid in it? I sure hope you didnt dump engine coolant into your trans
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
