Old 03-25-2003, 10:13 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
bent valves and linkage pin
so idk if any of u guys know but my timing belt broke on my car. so i was gonna replace the timing belt. had alot of trouble with the center bolt, but i just turned up my compressor to 150psi and my 1/2 impact spun it off really easy. so i repace the belt and i try and start it, it doesnt start, so i do a comp check, found out #2,3 dont have any compression, so it looks like i bent the #2 intakes and #3 edxhaust valves, which sucks but i am doing a ls swap anyways so it doesnt matter. it looks like the belt broke because of the water pump, cause the water pump was gone.
so the other problem i am having is htat the damn shift linkage pin is driving me nuts. i was trying to use a gear puller to push it out, but i just ended up bending a creasten wrench. i think i am just gonna drill it out and get a bolt and nut thing in there. dah i am getting very frustrated. ok well thats it
Team Lonely Drivers
Old 03-25-2003, 10:26 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
that sux
but at least ur problems and not mine hope u get that ls soon
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 03-25-2003, 10:34 AM
sciamop sciamop is offline
RE: the linkage pin... Get a punch set from Sears; It's like US$7.
Todd
91 SI
Old 03-25-2003, 02:00 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
I would double check that you have the #1 cyclinder at TDC and make sure that your not off on the timing marks. Also how fast were you going when it broke ?
Old 03-25-2003, 07:52 PM
i got the pin out and i ended up breaking my gear puller. now another problem is that the linkage is still rusted stuck on the tranny
yeah i used a punch to get it out once my gear puller pushed it out alittle bit
timing is right on, it was just at cruisin speed when it broke
Team Lonely Drivers
Old 03-26-2003, 04:52 AM
To get the linkage off the tranny heat it up a few times and use a hammer and put a bar or something on the lip of the linkage.
