Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '97+
Old 02-15-2009, 10:37 AM
Zerb Zerb is offline
PO118 - How Serious?
My 2004 GLS - 4Motion flipped the code: PO118 and I cleared it. Did it again ~ 4 miles later -I think the platform uses -2- of these sensors - one for the gauge, and one for the ECU, the second one believed to be the culprit. How serious is this - and exactly (picture) where is it - on the tranny side of the engine, down the radiator hose line - under the car???
Old 02-15-2009, 09:56 PM
Franco2112 Franco2112 is offline
Re: PO118 - How Serious?
The code your getting PO118 is the common vw coolant temp sensor. Unknown as to where yours is located on this vehicle. Most are on the drivers side by the MAF. Get part from dealer $27 or lower and get the diagram for install. Remember if you change the part yourself you will also need vw coolant for loss.
I would change out asap.
Franco
Old 02-18-2009, 10:08 PM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
if its a 1.8t its on the back side of the engine, under the pcv hoses on a coolant flange. Its either a black or green 4-pin round connector
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
