Go Back   Automotive Forums Car Chat > Mitsubishi > Endeavor
Old 02-15-2009, 10:08 AM
crazy cooter crazy cooter is offline
08 endeavor engine noise
This noise is a humming type noise coming form the engine. It usually occurs when driving for a while--10 or more mile, and coasting into town. when you accelerate from then on, it will give a humming noise until a higher rpm is reached--approx 1800 rpm. any suggestions?
Old 02-17-2009, 12:02 AM
RahX RahX is offline
Re: 08 endeavor engine noise
2wd or awd?
Old 02-22-2009, 11:53 PM
It is AWD. This noise has only recently came about. It didn't do it when new. The fluids are all good, and seem fine--I'm a Diesel Mech., so I've looked for the obvious. It doesn't do it all the time, and didnt do it when it was at the dealership--as usual!!
Old 02-23-2009, 01:11 AM
There was a tech tip in a Mitsu news letter from last year (not sure what month) but it addressed an odd noise. The rear driveshaft carrier bearings start squawking and the sound travels through the driveline and end up sounding like a rear diff or a belt noise that comes in between 1800-3200ish rpms. Try disconnecting the rear drive shaft and see if the noise goes away. MOST of the time it is the driveshaft but SOMETIMES it is the rear end.
Old 02-23-2009, 10:56 PM
Thanks for the input--but back to the dealership for this one!! Still under warranty, and they WILL fix it!!!
I'll let ya know what I find out.
Old 03-26-2009, 01:34 AM
coolworld coolworld is offline
well i will suggest you to go to workshop of your car and ask them to solve your problem then you can drive your car without any noise.
Old 03-26-2009, 06:24 PM
Wow coolworld why don't you just troll the entire place and spam it up with your terrible english and your justluxe ad.
Old 08-11-2009, 06:31 PM
Well third time back to the shop for the same noise. Two drive shafts (second was worse than first)and a rear diff this last time. Man I hate having problems. We'll see. the misses is on her way to vacation. Better not break down. I am starting to lose confidence.
Old 01-22-2011, 07:52 AM
richellemedina richellemedina is offline
I helped, but apparently did not want to recognize the people likely to be able to identify the problem with dealer. If you have had a bad experience, try another dealer. We have two engineers and two technicians master Master Elite.
