Old 02-15-2009, 07:33 AM
steveb2001ZR2's Avatar
steveb2001ZR2 steveb2001ZR2 is offline
Radiator cap lbs
I got an leak, so I went down got an new radiator, thermostat, and cap, I just seen where they gave me an 16lbs, the manual calls for a 15lbs, that is what was on there.
? is does it matter that much, or do I need to get an 15lbs cap?
I have not started it yet, as I still have the trans filter to do today.
Old 02-16-2009, 12:09 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: Radiator cap lbs
The parts store did the same thing to me about a month ago when I replaced my radiator, cap, and hoses. I didn't even notice it until I had put the new cap on. I can't say you'll be 100% fine, but I've run 1,000+ miles so far while trailering with no problems other than the occasional leak from a hose clamp. Having a new radiator is a plus, too.
I would check the fitting screwed into the water pump that goes to the heater core hose as well as the fitting screwed onto the back of the intake manifold. Some of these are made from die-cast zinc and prone to corrosion. Mine actually sprang a leak from the side, only to find out the threads holding it in were nearly eaten away. I had to remove and flush out the water pump to get any pieces out. My heater core had some in it too. If the part is magnetic, then you're okay, but check it for excessive internal rust. Some will just replace them with a NPT to hose adapter, but Dorman makes replacments in the HELP! section of the parts store. Just an FYI since you'll have it drained. Hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
