Old 02-14-2009, 06:59 PM
leochick1 leochick1 is offline
Angry Please Help Me
I changed my starter in my 1996 Sunfire and now the anti theft light is on and wont go off,and the car wont start either but will turn over. Its the only car i have so please help me.
Old 03-26-2009, 12:17 PM
roger0520 roger0520 is offline
Re: Please Help Me
turn your key on without trying to start it and wait about ten minutes and watch for the anti-theft light to shut off when it does turn the ignition off and then restart it. it should start right up. if not you may have to unhook the battery for a few minutes and hope it resets. if it has a passlock like i think it may then what i told you above should work. just watch for the light to shut off then turn ignition off and then restart
Old 03-27-2009, 06:46 PM
J-Ri's Avatar
J-Ri J-Ri is offline
Re: Please Help Me
Also be sure you got all the wires back on the B+ terminal on the starter, may have no power going to something. Some cars have several wires coming off the starter B+, so take a look around.
'04 Cavalier coupe M/T 2.2 Ecotec
Supercharged 14 PSI boost, charge air cooler, 42# injectors
Tuned with HP Tuners
Poly engine/trans/control arm bushings
Self built and self programmed progressive methanol injection system
