Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 02-14-2009, 06:30 PM
Goodridge_E5 Goodridge_E5 is offline
Exclamation which way do i turn the passenger tie rod to get it off?
i have tried to turn it right and its not budgeing and the tie rod is very rusty got some wd-40 and sprayed on there but it still won't work i can get it to turn either way!! please help!!
Old 02-14-2009, 11:53 PM
96tsport 96tsport is offline
Re: which way do i turn the passenger tie rod to get it off?
Here's a recent thread. The key is HEAT if its really seized & I'm not talking propane torch heat. I'm talking enuff heat that the metal in the area is fully (right thru) a bright orange color.
Should be normal counterclockwise to unscrew.
~70k last 3 years with no major issues ~270k total; unknown prior history.
Old 02-15-2009, 10:14 PM
yellowfiero yellowfiero is offline
Hey, I feel for ya! Mine was the same. Get some Map gas on it. I heated mine for over 5 minutes before it began to budge. Better yet, try acetylene if you have access to it.
Old 02-19-2009, 10:26 AM
Joe8888 Joe8888 is offline
Just did a rack & pinion on 94 Transport. Tie rod ends unscrewed easily after breaking them from the nut. Could not unscrew the nut without a lot of heat, (used oxy accety).
Old 02-20-2009, 01:23 PM
Talking Re: which way do i turn the passenger tie rod to get it off?
You're lucky. I got my jam nut off, but the tie rod end was fused. Heat baby, heat!
