Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-14-2009, 02:45 AM
97GSTspyder's Avatar
97GSTspyder 97GSTspyder is offline
Send a message via AIM to 97GSTspyder
Wrist Pin Question
So I got the entire motor ripped apart. There was quite a bit of heavy sludgeon the oil pickup screen. My rear main seal was leaking, and the gasket for the pump-to-block seemed to be leaking. The oil rings on all pistons seemed to be in *decent* shape, compression rings looked amazing...And the rod bearings looked damn near new
So here's my question. You guys know how the rod on the piston slides side to side a bit? Well I started cleaning the #1 piston in my parts washer. After scrubbing it lightly with a toothbrush and letting it sit in the cleaner for a few hours, I pulled it out and the wrist pin seems a little shady. When moved to one side of the piston skirt, the rod freely and easily swings to the front/back on the skirt. When the rod is slid to the other side of the skirt, it doesn't seem to want to swing front/back. Seems a bit tight, until I slide it back to the other side.
I don't know if it did this before I started cleaning it, I should have payed more attention. The other 3 pistons, however, don't do this. They all slide/swing perfectly.
Would it be because I started cleaning the piston and all of the oil that was on/in the piston is now gone, causing the sticking? If that were the case, I would think the rod would be 'tight' on either side of the skirt...
Thanks for any help.
Old 02-14-2009, 06:47 AM
ned032002's Avatar
ned032002 ned032002 is offline
Re: Wrist Pin Question
^ good answer...
