Go Back   Automotive Forums Car Chat > Cadillac > Deville
Old 02-13-2009, 11:59 PM
96DEVILLE 96DEVILLE is offline
97 deville pcm
What is a pcm and were is it....does this control fuel inj
Old 02-14-2009, 01:01 AM
Godofwarmike's Avatar
Godofwarmike Godofwarmike is offline
Re: 97 deville pcm
The PCM is the computer for most all electrical functions of your car. It controls when the fuel injectors open and what order they go in. Not sure where your PCM is but usually is near the fender on most cars. it is rectangular about the size of your hand and can be seen without the use of tools. there are several plugs in it with many many many wires going to it.
Does your car have a problem? if so listing them will help others to assist you in answering your questions.
1999 Purple Plymouth Neon SOHC Automatic
Bought Feb 2009 For $700
125,000 miles
Maybe the world record for car with most hidden zip ties
Old 02-15-2009, 08:54 AM
DFBonnett DFBonnett is offline
Re: 97 deville pcm
On my Eldo it's up under the dash behind the glove box.
Old 02-15-2009, 08:24 PM
Reflash Reflash is offline
Re: 97 deville pcm
It's located under the air cleaner box. Remove the whole air filter assembly and you'll see it
FWIW...if your replacing it with a reman unit...the PCM will have to be programmed. This requires a software download and upload to the replacement PCM
