Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-13-2009, 07:20 PM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
split second tuning
hey guys, i have just now become somewhat familiar with the fuel controller that has been installed on my 2g, and i was wondering, b4 i try to do this by feeling around int he dark, if anybody has any experience using the little fuel/ignition timing controller....
theres a software disc, and u plug your laptop up to the box under the hood and pretty much work out your fuel map
the car was bought from mississippi, and now is in nc, so it needs to be tuned to this atmosphere and everything so...any help out there??
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 02-14-2009, 09:57 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: split second tuning
Your talking about tuning portfueler? I have never used that but tuning will still be the same. Do some pulls and log your a/f ratio with a WB02, look over the data you just got and see if there are any lean or rich spots. Plug into portfueler and lean/richen those spots on the map slightly. Do another pull and see keep making small changed till you get it how you want it.
What are you using to control ignition timing?
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 02-14-2009, 10:33 PM
no no no not portfueler...well i mean im using a portfueler, but i also have a fuel/ignition timing controller, its like a box under the hood screwed down in place, and its wired into everything
the portfueler is just a spacer in between the intake mani and the block and it has 4 holes, so 4 more injectors are there spraying fuel in, which is controlled obviously
but what happens is, i can get my laptop and a serial cable and plug up into the box under the hood and using the software disc i have, i can actively manipulate ratios across the rpm range, so its a pretty awesome little gadget, i guess its like a cheaper fuel management not crazy aem $2k stuff you know
but i was wondering if anyone had one and could give me advice b4 i start trying to tune...=)
Old 02-15-2009, 11:19 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Umm well we need to know what it actually is before we can give advice. What software is it? What 'box' is it? Pics? Hard to say anything when we have no idea what it could be except for Port Fueler.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-15-2009, 12:41 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Originally Posted by david-b View Post
What 'box' is it?
Wait for it...
wait...
wait...
wait...
Your moms!!
There it is.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-15-2009, 06:24 PM
http://images.google.com/imgres?imgu...%3Den%26sa%3DN
there thats it, i just rondomly found that picture of the product so i didnt have to go outside and take a photo of mine, since its dark out right now lol
but thats the box i was talking about
Old 02-15-2009, 08:02 PM
Holset powered 420a
Usually what I do is pull the ignition timing to around 10* under boost and tune the AF ratio and then add timing 1* at a time untill I get knock and then pull it back 1*. I use Det Cans to moniter knock. Look them up if you want they work good.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-15-2009, 08:34 PM
david-b's Avatar
Dave is THAT guy
Originally Posted by Blackcrow64 View Post
Your moms!!
There it is.
Walked right into that one.
75 Monte Carlo
Old 02-15-2009, 08:44 PM
det cans.....
i quickyl looked it up on here and i got a buncha links to info on the oil catch tanks lol
but yeah, i def have knock in low rpm w/ no boost in 1st, like right when i start off
i mean i drive it a certain way and avoid it, but its a hassle id much rather there be no knock
Old 02-16-2009, 07:13 AM
Holset powered 420a
http://forums.neons.org/viewtopic.ph...&highlight=det
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-16-2009, 01:41 PM
lol that is so cool, and i already have most of that junk
im gonna go get some ear protectors tom
where is a good place to bolt it just at the knock sensor? or what?
Old 02-16-2009, 04:00 PM
Holset powered 420a
Any bolt on the block, you cant use the head but the sound isin't as good. I used a bolt by the oil dip stick. I just leave the copper on the block and just slip the hose over it when I tune it. Im actually going to try and make one today that used a conputer speaker amp and a microphone to detect knock. It will be easier to drive with headphones on than all that hose.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 02-17-2009, 04:47 PM
Cool Re: split second tuning
thanks for the tip
