Old 02-13-2009, 05:35 PM
ekalley ekalley is offline
5.0 efi motor knocking
I bought a 1990 f-150 with the 5.0 efi motor. Ran fine when i got it three days ago. Going down the road i lost power and it started knocking. I checked the vacuum it is steady at 18inches. Compression is 100 - 115psi in all cylinders. When cold the motor doesn't knock until given gas. After it warms up the knocking gets louder. I'm lost please help
Thanks, Eric
Old 02-21-2009, 07:04 PM
dfordski's Avatar
dfordski dfordski is offline
Re: 5.0 efi motor knocking
Scan for error codes.
Old 02-21-2009, 08:39 PM
I tried that and not pulling up any error codes engine light never comes on either. I am in the process of getting the motor out i'm going to tear it apart hopefully I can see whats going on. Thanks for the reply
Eric
Old 02-21-2009, 10:01 PM
dfordski's Avatar
If your CEL light doesn't come on temporaraly at start up, the bulb is out or PCM prob.
Old 02-22-2009, 12:11 AM
It does come on at start up i took it to ford dealer they ran the test said no errors were found.
Old 02-22-2009, 12:14 AM
I think i'm going to just put all new cam bearings and rods it the motor and what ever else it needs when i tear it apart. Any ideas on what else i need to change while i have the motor apart.
Old 02-22-2009, 07:56 AM
rhandwor rhandwor is offline
Looking at the compression and knocking I would get it bored and install new pistons and rings while it is apart. Also do a valve job while apart. Sometimes lifters make noise but not a knock. For the amount of work to install new bearings I would do a rebuild.
Old 02-22-2009, 03:56 PM
dfordski's Avatar
Ditto An engine is only as strong as it's weakest link. My 87' 5L tests +- 2 psi of 180/ cylinder. Only 78k, the last 25k running synthetic w/ a stablizer added to insure upper end lube filming for start ups. Switching to Synth. after break-in will insure the most return on your investment!
