Old 02-13-2009, 02:43 PM
brianr8 brianr8 is offline
97 GT No juice to Fuel Pump
I unplugged the pigtail in the rear of the vehicle where it comes through above the rear crossmember and i have no juice to any of the prongs. Checked the fuses under hood they are good and bought a new relay which didnt change anything. Anyone have this problem?
Old 02-13-2009, 03:59 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: 97 GT No juice to Fuel Pump
Are you testing it with the key on within the 3-5 second prime cycle? The PCM commands the pump off after the the prime cycle if the key is not in the start position and no crank signal is present.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-13-2009, 06:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
you could remove the fuel pump relay and jump the two contacts that are switched by the relay, then go measure for voltage. Just make sure you jump the correct ones or you'll let them smoke out of your PCM.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
