Old 02-13-2009, 03:26 PM
wiskydelta wiskydelta is offline
Bybass hose from LIM to water pump
On a 97 k motor does anyone know if i need RTV on this plastic elbow, the old one seemed like it had some on it, also what are the torque specs for the LIM?
Thanks in advance
Old 02-13-2009, 04:56 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: Bybass hose from LIM to water pump
Thanks in advance
I assume you have new coolant elbows & they have new O-rings. No silicone sealant required, only a light coating of silicone lube spray. Torque for the UIM bolts are 10 N·m (89 in-lb) and the LIM bolts 11 lb-ft or 132 in-lb
Old 02-13-2009, 05:13 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Fresh coolant will also work as lubricant on the o-rings for installation. The RTV you saw was probably a former attempt to seal a leak there without replacing them. RTV will actually damage the o-rings, so don't use any with the new elbow.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 02-13-2009, 07:11 PM
Thanks guys, I have a new elbow, gesket set, Dorman UIM, thermostat etc. should keep me busy all this evening.
If anyone has the PDF files for this procedure please send to [email protected]
Thanks in advance
Old 02-13-2009, 08:21 PM
HotZ28's Avatar
AF Moderator Elite
Bill, check your email.
Old 02-14-2009, 06:39 PM
happydog500 happydog500 is offline
Are these the new specs? I keep getting mixed up. What where they before the change? I'm putting in a used low mile motor in a few days, and will put in a U and LIM. I want to have the right specs.
Thanks, Chris.
1998 Buick Park Avenue (best car GM ever made)
Buick Lesabre 1997, 191,000
152,000 - Motor R.I.P.
Used 111,000 Motor, All New Gaskets
Used 102,000 Transmission - SOLD
New Balance 662
Trek 8000
Old 02-14-2009, 10:43 PM
HotZ28's Avatar
AF Moderator Elite
Thanks, Chris.
Use the specs in the post above & disregard any previous recommendations!
Old 02-15-2009, 10:15 AM
Thanks people, 3 hours and 18 beers later and no leaks so far. I ended up looking at Bob Naylors guide after the fact, on the lower intake I didn't put any extra RTV around the water jackets, so I'm hoping that doesn't cause me any issues down the road. The only problem I really ever had was the coolant elbow had a small crack, but for $160 on a 170k motor if I can get another 50k out of it I'll be happy.
Thanks again
Bill
