Old 02-12-2009, 10:16 PM
cwoods88 cwoods88 is offline
2000 Caravan electrical issues
Looking for help with this problem:
When the van is not running nothing works (interior lights,power locks,headlights etc) basically anything that is from the constant 12 source. When the vans engine is running everything works like normal. I have checked the fuses under the dash and under the hood all is good. Done limited wire tracing and found nothing obviously wrong. Could this be the BCM? or is there something else I should check?
Not sure if it's related but the radio would work intermittently when this problem started but after a while stopped working completely.
Thanks for any help!
Old 02-13-2009, 04:35 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 2000 Caravan electrical issues
Ya, the BCM. Sounds like it's snoozin when it shouldn't. The BCM provides the grounds for the various relay coils. Try a reset by pulling the IOD fuse in the PDC next to the battery for 2-3 minutes. Might be marked "Memory".
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 02-13-2009, 08:32 AM
I'll give that a shot thanks! If I had to replace the module is it an expensive part?
Old 02-13-2009, 03:15 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
$100 from a junkyard, $250 off the internet, more than $300 from a dealership. Need to have it's software updated at a shop or dealership.
Old 02-16-2009, 09:03 AM
Thanks, everything is back working again. when I pulled the IOD fuse the fuse was actually in pretty bad shape, when it was tested it was fine but one of the "legs" of the fuse was separated from the body of the fuse so it gave an intermittent connection. swaped fuses and everything is back.
Thanks for telling me where to look!!
C
Old 02-19-2009, 04:12 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Great news. Thanks for posting the fix.
