Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 02-12-2009, 10:37 AM
nvious62 nvious62 is offline
need help with tranny problems
I just bought a 95 grand cherokee laredo with 5.2 v8 all time 4wd. The problem i am having is the transmission. It works fine when it is cold goes in all gears and will drive. When it gets warm it will go into all the drive gears but does not shift quite right. As for reverse it will not grab right away but when it does grab it grabs real hard then it will drive. Was wondering if anyone has any ideas on what to do? And if anyone could tell me what transmission come in this year cherokee.
Old 02-13-2009, 07:15 PM
wwwildman wwwildman is offline
Re: need help with tranny problems
You might have better luck posting this in the Grand Cherokee forum.
Old 02-14-2009, 06:15 PM
rallygt rallygt is offline
I believe your ZJ (Grand Cherokee) and a 46RH transmission (verify first) needs a band adjustment for both the front band kickdown and reverse band.
The front band adjusting screw is located on the left side of the outside of the transmission and to gain access to the rear band the fluid pan must be removed. There is a locknut and adjusting screw for each. Loosen the adjusting screw a few turns and tighten the Front band adjusting screw to 72 inch lbs then back the screw up 2 and a half turns. Then tighten the front locknut to 30 foot lbs, be sure the hold the adjusting screw from turning while tightening the locknut. Do the same for the Rear band except adjust to 72 inch lbs then back off 2 turns, and the rear locknut should be 25 foot lbs.
Old 02-15-2009, 12:29 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Moving to GC forum for you.
Make sure the fluid level is correct, and let us know how many miles you have on your Jeep.
Also, how long has it been since the trans fluid was changed?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
