Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-11-2009, 10:23 PM
Prix87 Prix87 is offline
FUEL INJECTORs
Hola amigos.
Purchased an 85 camaro with a v6/2.8 motor. Blew a bearing in the original motor so I replaced it with one having lower miles.
I replaced harm. balancer, timing gear,sprocket,spreader. Distributor.cap/rotor coil. plugs wires. waterpump.bought all new gaskets on intake. today purchased pace setter headers. I want new injectors but what is the significance of the lbs rating??? 15, 17, 19 etc... What am i looking for here?
Old 02-12-2009, 01:14 AM
Morley Morley is offline
Re: FUEL INJECTORs
The lb/hr rating is very important. The PROM chip in the ECM is programmed for the stock size injectors, if you go too big you'll over fuel the engine, if you go small it will run lean.
Old 02-15-2009, 09:48 PM
Re: FUEL INJECTORs
How can i find out which ones I need? Is it in the Vin #?
Old 02-17-2009, 11:21 AM
Re: FUEL INJECTORs
The OEM P/N is 17111297
