Old 10-22-2001, 02:41 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Stealth RT question?
I have a 1996 Stealth RT Twin Turbo.
Now the dilemma. I also have a 1989 Chrysler LeBaron GTC Turbo and I have a bought the chip from Mopar, otherwise known as the Mopar performance computer. This has given me a good amount of boost, now I would like to do the same with my Stealth, but being a Mitsubishi engine and turbos I can see why Chrysler has no chip for my car. I have not been able to find a chip anywhere else. I know that Forward Motion could possibly make me a chip but that me be costly. I also have a friend that has a 1992 Stealth RT non turbo with this same problem.
Anyone know where I might be able to find a chip for either of these cars?
Old 10-23-2001, 05:36 PM
VeilsideVR4 VeilsideVR4 is offline
You dont need a chip man Just buy a boost controller. Then you can set the boost to any level that you want, within your fuel limitations of course
IZ
3SI # 1187
Old 10-23-2001, 05:49 PM
Polygon's Avatar
The Red Baron
See, fortunately I can do that, but my friend however. . . . .
Old 10-23-2001, 11:46 PM
Dustin_S's Avatar
Dustin_S Dustin_S is offline
Send a message via ICQ to Dustin_S Send a message via AIM to Dustin_S Send a message via MSN to Dustin_S Send a message via Yahoo to Dustin_S
Exclamation Stealth R/T non Turbo????
If it doesn't have a turbo, it's not an R/T...Or it is an R/T with a different engine...Then Again, I'm not the Stealth Genious, it's just that I thought ALLLLLL R/Ts had Turbos...I'll just leave this question up to the bigshots.
So, Guys? what's the call?
Is there an R/T model without a factory Turbo? :help:
Old signature is old.
Old 10-24-2001, 02:49 AM
Shadowfax Shadowfax is offline
Send a message via AIM to Shadowfax
okay... there are R/T non turbos'
Ironically I have a Stealth TT and an 89 Lebaron GTC... you give me some advice on the GTC and I will help you along all you could ever want on the TT!!!!
Ryan
92 RT/TT
Mods- K&N, Accel 8mm plug wires, Accel Coil packs, IK22 Iridiums, RPSIII, Unorthadox Aluminum Flywheel/UDP, PST Carbon Fiber Driveshaft, MSD DIS4, HKS VPC, Apexi SAFC, Apexi BOV, Greddy Profec A, 450cc injectors, Walbro 255lph, 2.5" turbo-back true duals with Dynomax Bullets, X-pipe, emissions removed, TB coolant bypass, Short shifter, battery in trunk, KYB's, Porterfield Cross Drilled/Cryo rotors, Eneki RP01 18's, SMC Alchy Kit, 26" X 11" FMIC, custom 2"ID Hard IC pipes, Custom Front Clip, 1st Gen head lights (motors removed), exhaust wrapped, Clevite77 bearings, Raxles CV shafts, urethane mounts, 3/8th pump to feed fuel lines, dual feed setup, K&N fuel filter, probably more
Stock- Twin Turbos, Twin Intercoolers, All Wheel Drive, All Wheel Steering
Old 10-24-2001, 09:41 AM
Polygon's Avatar
The Red Baron
Do you have the manual or a automatic in the GTC? And also is it all stock?
Also, I have looked into and he does not have an R/T it is an ES.
I found there is the base RS, then his ES, then the R/T.
Old 10-24-2001, 02:13 PM
5spd manual in the GTC... I have an MSD blaster2 coil, getting an MSD 6Al, Going to a 3" exhaust, bleedervalve (set for 6psi), going to a different type intake (one that bypasses the heater), and that is all...
For the record
Stealth's until 94 had
Base 160
ES 220
R/T 220 and good lookin
R/T TwinTurbo- Beastly
Ryan
92 RT/TT
Old 10-24-2001, 02:42 PM
Polygon's Avatar
The Red Baron
Great then you have the good GTC.
A great way for a quick power boost is to get the Mopar performance computer. It is a simple chip, but it will boost up your turbo to about 15-20 pounds, it has mine at 21. I also replaced the intake on mine, and replaced the exhaust. I put magnecore cords and NKG plugs in it. I also put a centerforce clutch in as well as a new head with hydraulic lifters. The rest were merely cosmetic and stereo mods.
Old 10-30-2001, 11:46 PM
hmmm... I'll look into the computer.
As far as the Stealth TT goes... you wanna figure out how far you wanna go. If you are aiming for 12's... even low 12's... then you'll have a lot less cash to drop, and should get there easily.
If you wanna hit 11's, 10's or better... get ready for some bucks... mostly cause the parts aren't availible yet.
For 12's you need a Boost controller- get and Electronic just cause they are cool. Exhaust/downpipe- a lot of choices... and a K&N/ CAI type intake... that should put you knocking on the door or actually in the 12's. An aluminum flywheel, better clutch, and a carbon fiber driveshaft are a few good things that don't hurt anything and are typically nearly as cheap as stock replacements.
To get 11's or better, you need a better fuel system (darn our small injectors and wussy 190LPH pump) and most easily 13G or larger turbos. (it can be done on less... just not easily as of yet!)
decide how you wanna go... then lemme know... I'll give better advice then.
Ryan
92 RT/TT
Old 10-31-2001, 10:59 AM
Polygon's Avatar
The Red Baron
I have cars that can run 11's and below, so I guess 12's would be nice in the Stealth. Now what brand of clutch do you suggest? Right now I have a centerforce installed in it.
Old 11-01-2001, 04:36 PM
Centerforce is a good clutch... if you like it and it holds... stick with it. Otherwise, go with and RPSII or III.
Aluminum flywheel helps too.
for 12's, just deal with intake, exhaust, boost controller... if you wanna lessen some cost (in a way) buy an MSD DIS4 (2 stage rev limiter and better mileage) and get the Accel coils I have- then you can run copper champion plugs at 99 cents each instead of 10 bucks a plug... you don't get spark blowout then either
Ryan
92 RT/TT
Old 11-01-2001, 10:37 PM
Polygon's Avatar
The Red Baron
Hmm, now what are your thoughts on forced induction?
I hear everyone around here talking about it. I thought that is what a turbo or supercharger does, or at least that is how it works.
What do you think?
Old 11-02-2001, 06:36 PM
may have missed the point on that one... forced induction IS a turbo, SC or perhaps NOS.
If you have a TT then you have all the forced you need. Him however... that is different... he can use giggle... he can get a Knight SC, he can drop a JSpec TT motor in... or he can go stupid crazy and try a single turbo install... which is pretty much a losing situation.
Ryan
92 RT/TT
Old 11-03-2001, 08:08 PM
Polygon's Avatar
The Red Baron
That is what I figured.
His dad is a cop so NOS is out of the question. I guess his best bet is a transplant.
Old 12-01-2001, 07:14 PM
Mylacc Mylacc is offline
Send a message via ICQ to Mylacc Send a message via AIM to Mylacc
happy?
are you happy with your stealth r/t?
cause its suppose to be the same as the 3000GT VR4
only cheaper
course that little spoiler thing is ugly as sin but it can be fixed im sure
Check out my new 3000gt/Stealth Site! inflam52 3000GT/Stealth 7 07-15-2009 04:41 PM
dodge stealth questions ASAP chgreenfrog 3000GT/Stealth 6 04-27-2008 06:45 PM
3kgt guy with stealth questions AutostradaVR4 3000GT/Stealth 12 09-16-2007 08:35 PM
3000gt/stealth question thepaivaVR-4 3000GT/Stealth 9 02-05-2005 03:10 PM
several stealth questions Rothrandir 3000GT/Stealth 8 09-21-2004 07:38 PM
