Heater core
Hi All,
Your precious help & advise are needed again: Lesabre 2001 custom (~80K miles), few days ago the weather went cold, and I used the heater (single temperature lever, not dual a climate control module), and when before i went out of the vehicle, i noticed few cooling liquid drops on the passenger side carpet, I also smelled the cooling liquid when the heater was on. My main suspect is the heater core, is there a valve that could leak when moving the temperature lever to red (hot)?, is it a common problem? My second question, what should i take off to get to the heater core? (assuming it is my problem) again, Thanks for your help
Re: Heater core
No valve, just the core! The core is in a box behind the glove compartment. Not an easy job, unless you are young & nimble.
Knowledge can be communicated, but not wisdom! ![]() ![]() |
Re: Heater core
![]() I took of the glove box, couldn't figure how to proceed, so i took off all the dashboard, then i saw the black heater/AC box (unit), i took all the small screws i saw, but still ![]() please take a look at the 2 pictures of the current status: http://sites.google.com/site/lesabre01site/Home/pics should i take the whole black box out? (for some reason, i believe the AC lines should be dis attached to take the whole box). in the second picture, i see a heat exchanger, is it the AC or the heater core?, and any idea how to reach the heater core lines clips behind the engine? any help is appreciated. Thanks. |
Re: Heater core
If you pull the box apart, you should see the core, it looks like the one shown below.
OEM Part Number 52482185 Physical Size 10 1/2 x 7 x 1 Inlet 3/4 Outlet 5/8
