Old 02-10-2009, 07:23 PM
mike14837 mike14837 is offline
ford 4.2 motor misfire
I have a 2001 f150 2 wheel drive 5 speed with the 4.2 litre. I have had a skip or misfire for about a year now, it hasn,t got worst or better. It also seems to be at lower rpm's. I have changed the plugs, wires and coil pack and didnt help, any ideas would be great thanks
Old 02-10-2009, 08:36 PM
tempfixit tempfixit is offline
Re: ford 4.2 motor misfire
Welcome to AF.
Have you checked for any codes?
Old 02-11-2009, 06:19 PM
Yes i have and there is none.
Old 02-12-2009, 12:31 AM
discnik discnik is offline
Have you tried doing a manifold vacuum test ? Should be 19 - 21 in. HG @ idle.
You could have a small vacuum leak.
Have you performed a compression test on the engine ?
I have seen instances where carbon build-up on the valve lip can cause a misfire.
Have you tried running Sea Foam through the engine ?
Some people swear by this for cleaning up carbon deposits.
Try checking and cleaning the EGR and IAC valve
Do a fuel pressure test , should be 35 - 55 psi.
Just some starting points.
Old 02-13-2009, 05:09 PM
thank you for the ideas i haven't tried any of them. ill let you know how i make out after i do some of your ideas thanks again
Old 03-01-2009, 03:06 AM
caribbeankruzer caribbeankruzer is offline
How can I find how to run sea foam through an engine. Where do you buy the foam at.
