Old 02-10-2009, 02:39 PM
atazman atazman is offline
F-250 Super Duty Diesel brake issue
1999 F-250 Super Duty diesel 7.3L 4x4 with 290,000 miles
Problem: I have little to no brake pedal in this vehical and a when applying the brakes or turning the steering there is a rather loud groan type of noise.
The rear calipers and brake pads were recently replaced to fix a leak in the right rear caliper. The leak was what I thought the problem was related to.
The brake lines were bled and I have brake pedal about 1 out of every 10 times I pushed the pedal. I noticed that the power steering pump has a leak and that the power steering pump and the hydraulic module in front of the master cylinder were connected by a hose. Since these are connected if I replace the power steering pump will it have any affect on the brake system?
I am used to working on vaccum assisted brake systems.
Thank you
Art
Old 02-19-2009, 07:09 AM
big white bufflo big white bufflo is offline
Re: F-250 Super Duty Diesel brake issue
the SD diesel has a hydro boost it uses the power stearing pump for brakeboost sound like your powerstearing pump went bad
Old 02-19-2009, 07:07 PM
fordtrucksonly's Avatar
fordtrucksonly fordtrucksonly is offline
I'll second that ^^^
"When Lightning Strikes the Heartbeat Stops!"
'91 Mustang LX 347 StRoKeD & BlOwN
'04 Ford F-250 6L PS FX4
'95 Ford F-150
Ford Racing Pride
General Motors who?
2004-2008 Ford Master Certified Technician
Old 02-23-2009, 11:53 AM
Thanks for the reply's. I also checked with a good friend of mine that works at a Ford dealership garage and the more I explained the issue the more positive he thought it was the master cylinder. So I replaced the master cylinder and the left front caliper, since I broke off the bleeder valve. After bleeding the brakes I had more pedal than before and the groaning noise from before had vanished.
Thanks again for the reply's and all the looks.
Old 02-28-2009, 01:26 PM
Andrew65 Andrew65 is offline
I have a 2001 f-250 with a 7.3 diesel. I just bought the truck. When I got it the rear brakes were shot, the left rear pad had fallen off and the rotor and caliper destroyed eachother. I replaced the calipers and rotors and oviously pads too. My brakes pump up decently with the enging off, When I start it up the brakes go an inch from the floor. I have replaced the mastercylinder and the hydro booster. The brakes work, but are NOT great. The petal just isnt solid like it should be. I have bled the lines about 10 times now, hoping to get a better petal. Still no good. Anyone haved any suggestions???
Old 02-28-2009, 05:55 PM
rhandwor rhandwor is offline
If you have anti lock sometimes you need a scanner to pulse the pistons to get all the air out.
If you have rear drum brakes adjust the rear shoes until they barely touch when turning by hand.
