Old 02-10-2009, 08:43 AM
rjeffery rjeffery is offline
Fuel Pump Check Valve (Again)
Does anyone know if there is a way to fix a bad fuel pump check valve without having to replace the entire pump (running solvent/cleaner in gas, remove and clean pump, ect)? I have fast fuel pressure leak-off after shut down. I replaced my fuel pump 2 years ago for the same problem (with Delphi pump). Thanks.
2002 1500 Ext. Cab 4.8L 2wd.
K&N FIPK, Cat Back Exhaust, Rancho RSX Shocks, Silverstar Headlights High & Low, Infinity Reference Door Speakers & 10" Dual Voice Coil Sub. 265/75/16 BFG AT/KO's, Spray-In Bed Liner, Hella FF75 Fog Lights, Hella FF75 Driving Lights.
Old 02-10-2009, 09:10 AM
j cAT j cAT is offline
Re: Fuel Pump Check Valve (Again)
the injectors could be leaking...does it smoke on start up ?
what pressures are you getting ?
what is the engine doing ?
Old 02-10-2009, 09:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
What year and truck and engine?
First thing check the system to find out where the leak off/down is.
Many places it can leak off.
For a fuel pump leak off test hook a fuel pressur gauge direct onto the inline at the fuel filter.
Prime fuel pump up to running pressure and watch for leak back.
Does it leak off there?
MT
Old 02-10-2009, 11:26 AM
Engine does not smoke on start up and runs fine once started. Engine idleing about 55 psi. Key on, engine off spikes to 60 or so then bleeds off. Engine has trouble starting on 1st crank due to no fuel pressure, will start on 2nd crank.
Old 02-10-2009, 11:37 AM
2002 4.8L 1500 Silverado ext cab (other specifics in sig). I will try to get the gauge on the fuel filter later this week. FYI, I did change the fuel filter just before this started happening, maybe I need to check those fittings...
Old 02-10-2009, 12:56 PM
you say no fuel pressure on first crank....if you have no pressure this may be electrical...the fuel pump relay,the fuel pump ground ,and insuring that the fuel pump has 12volts going to it when key is at ignition on position...the fuel pump ground is at the fuel rail next to tank....
the fuel pressures of 55-60psi are normal...it should hold the pressure for 10 minuites or so ....
if you have no DTC failure codes the ECT can cause a cold start problem...the injectors may not be commanded to stay on long enough to give the engine the proper amount of fuel ,,if the ECT sensor reports that the engine is warm...
Old 02-15-2009, 09:37 PM
Ok, I checked the fuel filter and it is tight. Fuel pump runs for a few seconds when ignition is first turned on so I don't think it's electrical. Still have a rapid leak off after fuel pump shuts off, wasn't able to connect my gauge at the filter b/c I don't have the right fittings. So, back to my original question, is there some sort of solvent/cleaner I can put in the tank to clear up a stuck check valve, or do I just need to pony up the $ for a new pump?
Thanks.
Old 02-16-2009, 10:05 AM
Thanks.
so once again ,,,,what is the fuel pressure when key is in the ignition position for the first 2 sec....? IN PSI......
THE vacuum line to the fuel regulator ,,,did you check for fuel residue...the diaphram splitting causes this...
when cranking can you see the fuel pressure pulsing as the engine rotates and does it hold pressure with in the correct range ?
