Go Back   Automotive Forums Car Chat > Saturn > SC/SL/SW
Old 02-09-2009, 03:37 PM
aeflower9 aeflower9 is offline
Smile 2000 s engine blown!!
How hard is it to replace these engines does anyone have a step by step or just some usefull info that i might need to know about this car!! I put oil in it and it just pours right back out on the ground. And what else should i change while doing this. the car is an automatic thanks everyone!!
Old 02-09-2009, 05:11 PM
RC1488 RC1488 is offline
Re: 2000 s engine blown!!
Vitals? Model?
Ive posted videos before on how to remove the engine. I believe its easier to drop the entire drivetrain from the car which gives you much easier access. Others suggest removing just the engine/tranny from the top. Your call. No special tools are required. You will need a 30mm socket for the drive shaft nuts. Stuby ratcheting wrenches are nice. PB Blaster is your friend.
Untill you post your vitals do NOT get another engine. You need to be specific in the new engine your choose so that it minimizes chances that something doesnt fit.
Present: '02 Sl1 Man '01 SC1 Man '97 Sl2 Auto '96 SL2 Auto '95 SC2 Man
Past: '99 Sl2 Auto '97 Sl2 Man '98 SL2 Man '95 Sl2 Man '95 Sl2 Man '94 Sl2 man
Old 02-11-2009, 07:22 PM
The car is a SL 1.9 L, the car is my relatives car and the mechanic said that she did not put oil in the car, he said it needed a new engine. Im getting the car for free all i have to do is put the engine in it which i found one with 70,000 on it for 400 from a local junk yard.
Old 02-11-2009, 07:54 PM
Year and type of the donor engine?
Old 02-16-2009, 11:44 AM
rloya99 rloya99 is offline
i just change one it not easy u have to take all the pulley from the font of engine off then take bolt from top of tranny and push tranny back and u also have to take the muffler complety off if not just be carefull when pulling it out not to damage sensors on the intake not easy k but it could be done form the top 4 hours
Old 02-22-2009, 10:03 AM
not sure about the year of the motor but it is supposed to be the same motor from the same car.
