Old 02-09-2009, 12:23 PM
homegrowm311 homegrowm311 is offline
The clunk is gone
I have to say thanks to the forum, you guys saved me at least a few hundred dollars this weekend. I had the infamous clunk when starting from a stop and it was due to the slip yoke. I put my truck up on stands and was happy to find no problems with the u-joints, solid as can be. 20 minutes later I had the drive shaft off, greased and re-assembled. Now, not a sound at the stop lights.
Old 02-14-2009, 08:03 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: The clunk is gone
hate to be a party pooper, but it'll come back in about 4-5 mths. The only way to really fix it is to replace that yoke with nickel plated one.
Old 02-17-2009, 02:19 PM
I know it's not a permanent fix. I'm fine with spending 30 min a few times a year to keep things silent and I've got enough grease for years. When the u-joints go bad, that when I'll look into a nickel plated yoke.
Old 02-17-2009, 02:29 PM
ukrkoz's Avatar
that is all cool.
now, do this: next time you pull the d-shaft, grab the output shaft in trannie and move it upside down. don't be surprised should it wobble and clunck.
I am dead sure that bind from the yoke messes output shaft suspension.
just a friendly observation.
Old 02-17-2009, 03:49 PM
j cAT j cAT is offline
let us know how this works out...it could be worn but maybe not...if it lasts a few months it should be good..
Old 03-12-2009, 09:32 PM
gremlin96 gremlin96 is offline
found a quick fix and check. get some sea foam deep creep. and spray at the base of the shaft under the dash. you will see ware the shaft joint is just be for the floor. soak it a bit then drive around the block repeat a few times. clung gone. don't know how long it will last but a few bucks for a can cheep fix. tood mine away and its been over a week.
Old 03-14-2009, 10:25 AM
Mod_12 Mod_12 is offline
What type of grease did you use? What all did you grease? I am about tired of hearing this same noise. Thanks
Old 03-14-2009, 10:30 AM
jyount jyount is offline
Are you guys talking about the driveshaft slip yoke or the steering slip shaft, cause there is responses talking about both....
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 03-14-2009, 11:04 AM
ukrkoz's Avatar
he's talking about driveshaft slip yoke. it rusts and bind to trannie output shaft. the way it is all designed, truck wheelbase changes some when you take off. this movement is supposed to be accomodated by the slip yoke splines moving on the output shaft splines. cheap as GM is, they made yoke out of some "cost efficient" metal, so it rusts and binds to the output shaft.
ISS - intermediate steering shaft - is flawed designed for over 10 yrs, as folks on brand spanking new trucks have same issue. you can keep lubricating it with whatever, or you can replace it with a NAPA design and have it over once and for all. OEM design replacement will return the problem in about 7-8 mths. I know.
Old 03-14-2009, 03:28 PM
I know both problems, just saw both responces, so wanted to clear it up for anyone involved. The driveshaft slip yoke was uncommon when I worked at the dealership but I must have greased about 9 hundred zillion iss and replaced atleast 1 hundred. The general warratied it for a while, then they just went back to greasing it for warranty. The stupid thing is they didn't change a thing, they just kept producing them with the same junk shafts for years even when they new full well it was a customer complaint.
Current job: RN
Wife's
Old 04-19-2009, 11:56 AM
dakota1205 dakota1205 is offline
what kind of grease did you use. I have a 2000 Z71 with same problem. I had a dealer lube it, it seems like it lasted maybe 6 months. If I can do it myself, I can save some costs.
Old 04-19-2009, 03:38 PM
ukrkoz's Avatar
you want to use GM original lube with PTFE. #12345879. it is, indeed, a very good lubricant. works very well on garage door hinges and any zert in GM creations.
now, here how goes it. you go to dealership and ask for the 800 gram can of it. they say Sure and quote you about $45 plus tax for it. You raise your eyebrow, frown, and say that you can buy a can of lube with PTFE (practice PTFE at home, so you sound like you've been dealing with it for eons) at any hardware store for less than 20 bucks. which is true, lithium grease with PTFE is around 10 bucks at HD.
my local dealer immediately gave me discount and sold it for $25. it is good lubricant though, no sarcasm.
as a dish on the side, I am membering in 5 Chevy forums. basically, that slip yoke clunk is all over the web. starting 99 and up to the latest models, as I saw some on 08 ones.
Old 05-14-2009, 04:30 PM
I realized that it's been about three months since I greased the splines of the slip yoke. So far it's still silent but I know it won't last forever and I imagine that I'll start hearing things again in the next few weeks.
Old 05-16-2009, 10:43 PM
kahjdh's Avatar
kahjdh kahjdh is offline
Im about to order a slip yoke to the tune of $225, what should i lube the new one with so its not dry when I put it back in?
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
Old 05-17-2009, 11:16 AM
ukrkoz's Avatar
well, here's a million dollar question: are you ordering a NICKEL PLATED yoke? as if you order same OEM metal one, you might, as well, just go to junk yard, buy used one GM made, sand blast it, lub with GM grease with PTFA, and be back to same problem sooner, than later, just at much less expense.
Reason GM went to nickel plated slip yoke was cuz it does not rust and bind with the output shaft. I was quoted over $400 dealership for the swap. If you found nickel plated one for $225, let me know where at, as I could not find one on the web, and I am VERY GOOD at this. I shall definitely appreciate tip, as it is continuous aggrevation to listen to that clunk. Also, I am planning to rid of this money pit, so selling it with that thud in the rear will definitely lower the value.
