Go Back   Automotive Forums Car Chat > Nissan > 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX
Old 03-24-2003, 11:25 PM
Nimex Nimex is offline
Send a message via ICQ to Nimex
Turbo KA24E ?
I was just curious as what would have to be done to turbo charge my car. I mean like everything that is needed, because this what I'll be going by when I purchase the supplies. Also, if the engine is in great shape, will a rebuild be necessary? Thanks for all the help, once again.
Old 03-25-2003, 02:45 AM
SR20DETpower SR20DETpower is offline
Banned
Send a message via AIM to SR20DETpower
I would defintely rebuild a KA24E before turbo'ing it, most have high mileage, Im even going to rebuild my DE when it gets turbo'd just because starting fresh is so nice.
Old 03-25-2003, 03:12 PM
Robs240 Robs240 is offline
Hi
Nimex I am new here also and sorry I have no answer to your questions but do have a question for SR20DETpower. How would you build a naturaly aspirated ka24e? I just got my car to and know nothing about 240's. Thanks a lot.
Rob
1990 240sx- 5sp.
2000 Camaro Z28-A4
Old 03-25-2003, 03:46 PM
Suislide's Avatar
Suislide Suislide is offline
you don't have to build a naturally aspirated KA24E. that's the engine that comes stock with all 1989-1990 Nissan 240SX's. from 1991 on, they got the KA24DE, which is the twin cam version of the KA24E.
-Brian
2013 Subaru BRZ Sport-Tech 6MT. Not stock.
Old 03-25-2003, 03:54 PM
ok thanks. Do they sell a bolt on turbo kits for the ka24e? Thanks again.
Rob
1990 240sx- 5sp.
2000 Camaro Z28-A4
Old 03-25-2003, 04:48 PM
Suislide's Avatar
yes, yes they do. i'm not an expert on it though (i'm an SR20 man myself), so one of the KA guys could maybe help you out.
-Brian
Old 03-25-2003, 05:24 PM
Banned
welp heres how it goes.... if it was me personally I would either transplant in a KA24DE to start with........ or just go the SR/CA turbo engine route.........
Heres some rational behind my thinking......
with the DE you get another boost of 20hp compared to the Single cam KA24E motor. If you wanted to build a naturally aspirated engine I would also stick with the DE engine, if you want to do an engine swap. Basic steps at building an NA 240sx
and I would do it in this order
1.-Short Ram Air style intake on the manifold side.. don't route it to the drivers side like stock..... move the MAF, cone style filter.
2-Header
3-Complete exhaust overhaul from the header back. I would try to custom make 60mm mandrel bent piping from header to the end of the cat, replacing it if u can....if not get a high flow cat....Then buy an aftermarket exhaust with good design and mandrel bends in the 60mm diameter area...you can find quite a few JDM exhausts if u look in that size.
4-Underdrive pulley
5-JWT ECU
6-Light Flywheel/Clutch upgrade(Shift kit, stall converter for auto)
7-Good set of grippy tires
8-Extrude Honed intake manifold
9- This next step would cover engine internals.....a wise man would just do it all at once...
-Cams
-new crankshaft
-KA24E stock higher compression pistons mid 80's years I believe
-Cam Gears
-test to get optimal cam gear settings and fuel mixture settings with the higher comp pistons.... recremend 93 pump gas for sure.
maybe I left a part out
with respectable tuning and a wise selection of cams/timing you would defintely be in the 175-180+rwhp range..... faster then most basic SR swaps... and most stock tired KA's dyno anywhere from 110-145
I wouldn't build a KA24E for an all motor street car personally.......
but if u want to keep the engine I would do a basic rebuild since most have high mileage for a turbocharged engine 100k miles+...... you can piece together a turbo kit or buy one already made up....usually a bit more expensive but better choice for the DIY'er who has backyard mechanic type tools and ability. Also if u wanted to swap in a KA24DE and turbo that....not a bad idea either.... you would take the same steps.
You also have the JDM engines.... the CA18DET turbo engine is 1.8L and around 140-160rwhp stock but has more potential then a NA KA for sure. That engine is a direct stock bolt on affair with hardly any, if not very easy customization tasks.... the SR20DET is for 91+240's chassis and bolts on into them but for your car you would have to customize your power steering lines or just insal 91-94 240sx ps lines in......
SR swaps www.srswap.com
CA/KA24DETurbo/other misc Nissan engine transplants(skyline engines) www.unstable-hybrids.com
and for the bolt on KA24E turbo kit...... this is one that I know of could be more...
http://www.realnissan.com/
7-
Old 03-25-2003, 05:34 PM
Banned
also after reading your first post...... your KA24E doesn't have that bad of mileage it could take mild turbo'ing in stock form now..... probably around 220-260rwhp depending on intercooled or not and turbo u choose. KA24E isn't a bad motor to turbo....many produce some high figures even above 400rwhp.... just giving u some other options but it seems like u want to keep the KA24E and it doesn't have that bad of mileage. and I do not believe the head of a KA24DE will bolt onto the block of a KA24E.
Wow great info from you guys! THANKS. I am still learning about the lingo etc about 240sx's. I have been a v8 guy for a long time but I have always loved turbo cars! A well built NA ka24e will also suffice me for now . I did notice how long the tube is from the intake all the way to the driver side. I think i'll do the shortening of that first. Many thanks again.
Rob
1990 240sx- 5sp.
2000 Camaro Z28-A4
Old 03-25-2003, 09:35 PM
What kind of power would I expect from the kits from realnissan.com ? And is there anything else I'll have to purchase along with the kit? Thanks for the help.
Old 03-26-2003, 12:25 PM
Banned
it looks like they have options in their kits so I couldn't really tell them..... email them inquiring about what you would like and see if they can help you out getting it.
Old 03-26-2003, 04:45 PM
TheLogikal1's Avatar
TheLogikal1 TheLogikal1 is offline
Send a message via AIM to TheLogikal1
would it be wise turbo'ing my s14 considering i have 90k miles on it?
Old 03-26-2003, 05:45 PM
Banned
it would be ok with a smaller turbo like a T25 or 28, such as turbos on stock SR engines... with good tuning it would be ok... With a Bigger turbo like on a T3/T4 or straight T4 to run maximum boost 25psi or so I would rebuild the engine with some better pistons and rods.
Old 05-23-2004, 03:23 AM
hexaine hexaine is offline
Send a message via AIM to hexaine
Ahem... I have no turbo knowledge:
1) What's the diff between high mileage / low mileage and turboing both of them? Pro/Con's? I have 170k+ on mine. What could I do? (1990 stock engine)
2) Wow, up to 260+ HP improvement? How much did these cost you (since you've probably done them already) and how hard was it to do?
Thanks! I'm sure more questions will brew from me later.
Crazy Go Nuts University Alumni
http://www.homestarrunner.com/
Old 05-23-2004, 01:29 PM
nissanfanatic nissanfanatic is offline
240SX Guy
Send a message via ICQ to nissanfanatic Send a message via AIM to nissanfanatic Send a message via MSN to nissanfanatic Send a message via Yahoo to nissanfanatic
Re: Turbo KA24E ?
High mileage engines are worn out. Compression test is a good idea. Custom turbo kits are cheaper. Oh and it's a good idea to not bring up six month old threads, much less a year old. Just some advice. Start a new thread.
-Cory
1992 Nissan 240sx KA24DE-Turbo: The Showcar
Stock internals. Daily driven.
12.6@122mph
496whp/436wtq at 25psi
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
