Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 02-08-2009, 08:51 PM
bhw33191's Avatar
bhw33191 bhw33191 is offline
Send a message via AIM to bhw33191
My caprice 0-60
Nothing special really i mean its only a 305..but i just thought i'd post this. Picking up a K&N filter soon cause i heard it can add up to an 8RWHP and also better MPG
I have one question though, in the second 0-60 run you can hear the transmission sort of "hang" switching from 1st-2nd gear. Compared to the first run however i might have been pushing the gas differently. Its kind of wierd because despite the fact, that was the faster run.
http://www.youtube.com/watch?v=040mfWaJIsg
'83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now.
-- 65,000 original miles --
Old 02-08-2009, 09:05 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: My caprice 0-60
Your 1-2 shift accumulator spring is probably broken. Every one I've seen is broken in the transmissions when I've taken them apart. This causes that 1-2 soft shift.
It's an easy fix but it involves removing the pan on the transmission, and then the 1-2 shift accumulator cover. On some transmissions, the spring goes between the piston and the cover, on others the spring goes between the piston and the separator plate. Observe the location of yours when you pull it out. You can get these springs from any GM dealer, go for the heavy duty one for your year. They are color coded and these colors are different for different applications. Your dealer should help - these springs aren't expensive. A heavy duty spring will give your car a 1-2 shift 'kick'.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 02-08-2009, 09:29 PM
mike561 mike561 is offline
Re: My caprice 0-60
Is that the little spring you were talkin about on mine too silicon? mine seems to get hung up around 40 mph, tranny's a 700R4
2006 Chevy Cobalt LS
Old 02-08-2009, 09:38 PM
bhw33191's Avatar
Re: My caprice 0-60
Shift kick? that sounds cool!
Old 02-09-2009, 01:22 AM
silicon212's Avatar
Confoundingly Lucid
Re: My caprice 0-60
What do you mean by 'hung up'?
The job of the accumulator is to soften the application of the band just enough so that the shift isn't harsh and no parts are broken (remember the TH700R4/4L60 reaction sun shell hub is subject to breakage in stock form). It functions by providing a 'space' for the piston application fluid to fill along with the piston in the servo, resulting in a controlled drop in application pressure. The fluid pushes against a piston in the accumulator, and the spring in the accumulator resists this, thereby regulating the amount of flow into the accumulator (and apply pressure to the servo). When the spring breaks, the piston 'floors' and the pressure in the apply line drops, causing the band to slip a bit on the drum due to the increased apply time caused by the failed spring.
The result is that when driving softly (normally) you might not notice it, but under high acceleration there will be a lot of slip during the 1-2 shift and that's why the engine RPM in the video doesn't abruptly change, but rather 'flows' down during the shift until the band servo fully applies. This will eventually cause a burned band and a possibly warped drum.
This should be the only effect of the broken spring.
Old 02-09-2009, 07:35 PM
Re: My caprice 0-60
well not actually hung up, more like stuck. i made that post a while back about how mine seems to get stuck around 45 mph and i have to floor it for a second to get it going more. I remember someone mentioned a TCC sensor could be the problem too.
Old 02-09-2009, 10:36 PM
coupeboy's Avatar
coupeboy coupeboy is offline
Re: My caprice 0-60
how do u get those profile pics on there
Old 02-10-2009, 06:56 AM
bhw33191's Avatar
Re: My caprice 0-60
Use a site like www.tinypic.com to upload the image, you will probably need to resize the picture but i think you can do it on that site when you upload it. Then you have to add the image code to your avatar under your profile.
Old 02-10-2009, 10:35 AM
Re: My caprice 0-60
[IMG]picture link here[/IMG]
Old 02-10-2009, 04:09 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: My caprice 0-60
Don't mean to get off topic but is this what you need to do to post any pictures into a thread?
I can't seem to find info on the AF site about this.
Thanks
Al
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 02-10-2009, 04:25 PM
Blt2Lst's Avatar
Re: My caprice 0-60
Thanks
Al
Never mind, I found my answer
1992 Camry LE 2.2
1996 Suzuki RMX250
