95 neon tail lights blowing fuses
Whenever I turn on my headlights the fuse for my tail lights keep blowing. i have replaced the bulbs and looked at the wiring but cant see anything wrong
Re: 95 neon tail lights blowing fuses
sounds like a short to me. not sure of too many other things that could cause that. did you check the wires and plugs at the lights to make sure no "weekend warriors" did any of their own wiring? I had a dodge stratus that someone soldered the pass. side taillight and it did the same thing you mentioned.
yes checked the wiring all looks good at the lights even used a meter to check to see if was a short to gnd at the lights but all is good
how many volts are running to the lights when you turn on your headlights?
also is it possible your putting the wrong size fuse in? someone may have changed it and put a lower number in than it should be.
