Cannot turn key in ignition
Hi
I have an 03 ls that the ignition is frozen. The shifter is in park but the steering wheel did not lock. I put my key in and the seats adjust but will not turn and shifter will not move. Is there a way to shift the trans into neutral so I can see if the linkage is the problem or the tumblers? Or does anyone have any ideas? Thanks |
Re: Cannot turn key in ignition
That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved. For with the heart man believeth unto righteousness; and with the mouth confession is made unto salvation. Romans 10:9-10 |
had that problem once...
here you may find some info http://www.google.com/custom?hl=en&c...%3Ac-6heqrjwqg |
I have shaken the wheel while turning the wheel does not help...the wheel is not locked can turn the steering wheel freely
Correct, no steering wheel lock on the Lincoln LS except for a few right hand drive Euro models where it is required.
The Lincoln LS has the key cylinder switch located below the instrument cluster, but not part of the steering column. There is not mechanical linkage that would cause the steering to bind the key cylinder switch like on many cars.
I didn't know about the Euro models. I wonder if they used an electronic lock on those or relocated the key cylinder switch to the steering column? -Rod |
Thank you for the help sounds to me like I should call the locksmith
are you pushing in on brake pedal also to see if that helps?
I have done that will try to have ignition changed
Thanks |
It must be electronic because it is on the dash, they use a different style Euro key also that can only be removed when in park. I got my info from another Lincoln LS site with a UK member who has posted photo's of his rare RHD V8, most that were imported were V6. UK model also have headlight levelers rotary switch on the dash, headlight washers, and different tail lamps(amber lens).
Also are you pushing in on the key while turning it?
I replace them all the time.Im a locksmith..the shitty thing it you need to get it to turn before you can remove it yourself...you insert the key all the way and tap it a few times with a soft mallet and it will turn again.
