Go Back   Automotive Forums Car Chat > GMC > Jimmy
Old 02-08-2009, 06:38 PM
ksue ksue is offline
93 S-10 Blazer- engine temperature gauge
The gauge is not registering anything at all. I will not be able to tell if the motor is running hot, or overheating. How can I fix this?
Old 02-08-2009, 07:26 PM
duke350 duke350 is offline
Re: 93 S-10 Blazer- engine temperature gauge
On the side of the block on the passenger side there will be the temp guage sending unit.
There is another temp sending unit towards the front under the 'snorkel'. This is the one most parts stores carry. The plugs on them are different, but they will screw in either place. Make sure you get the right one. I know NAPA carries both.
Old 02-08-2009, 09:32 PM
Thank you so much. I'll try that
Old 02-08-2009, 09:40 PM
I think these are the 2 diff plug types.
http://partimages2.genpt.com/partimages/647257.jpg
http://partimages2.genpt.com/partimages/501988.jpg
So, like I said, make sure you get the right one. Also, when you pull it out, it will leak coolant, unless you drain it first. Make sure engine isn't to warm.
Old 02-11-2009, 07:54 PM
I'm going to take these pictures with me to NAPA tomorrow. Thank you so much for your insight.
