Old 02-07-2009, 09:10 PM
Mark2106 Mark2106 is offline
Angry Can Someone answer this mind blowing Problem
I have a 1999 Malibu which is really my wifes car. My stereo was playing fine until my sister-in-law borrowed it. Now the stereo comes on but no sound. I replaced the factory stereo with a JVC am/fm/cd and I still have the same problem. I tried to just use the power leads and connect the speakers sep but still had the same problem PLEASE HELP my wife thinks I did something wrong This is starting to hurt because when we travel I HAVE TO listen to her talk about work
Old 02-07-2009, 10:37 PM
PlayStation3 PlayStation3 is offline
Re: Can Someone answer this mind blowing Problem
check you fuses, you will be admazed at what the radio is intrgrated into. minein my old car was intergrated into 4 different circuits. so check your fuses. and it sounds like wiring since u replaced the head unit. so that would be the second place to look.
what do u have the ground connected to?
Old 02-08-2009, 08:48 AM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
do you have an amp connscted to the head unit ?
Old 02-22-2009, 12:15 PM
AK47 SRH420 AK47 SRH420 is offline
Send a message via AIM to AK47 SRH420
check to make sure you dont have any bare wires touching, and then check your fuses cause you can blown them rather easy
Old 04-01-2009, 03:31 PM
freeashkee freeashkee is offline
Maybe youre speakers are blown out, if the left is blown out then the right might not operate. Its possible that all might not work if ones blown out.
Old 04-01-2009, 07:20 PM
Audio Guy
often times, if one speaker wire is grounded out it will shut the whole amp down.
