Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 02-07-2009, 09:02 PM
mark70669 mark70669 is offline
rough idle 95 k 1500
I have a 1995 k1500 305 tbi that has a rough idle.
I changed plugs, plug wires, dist cap, and rotor. No improvement. The plugs I replaced were only in for about 3k miles. They had a fair amount of black carbon build up.
Not sure where to go from here. Thoughts?
Old 02-08-2009, 02:23 AM
discnik discnik is offline
Re: rough idle 95 k 1500
Have you tried doing a manifold vacuum test, compression test, fuel pressure test ? Do a "fuel pressure test" search on the Chevy forum. "OldMaster" has the procedure.
Have you checked for spark, bright blue/white, at each of the plugs ?
Have you tried test the pick-up coil ?
Just some thoughts.
Old 02-11-2009, 12:44 AM
LordJebus LordJebus is offline
These are bad for carbon build up on the injector bodies and tips. You can clean up alot of the stumble <provided there is no intake leak> by using throttle body cleaner in and around the TB. Also get the fuel system pressure cleaned to clean carbon from the injectors. Should clear it up.
1992 Buick Lesabre LTD
1997 Mazda Protege
