Old 02-07-2009, 06:36 PM
vr4choke's Avatar
vr4choke vr4choke is offline
Send a message via AIM to vr4choke Send a message via MSN to vr4choke
60k tune up
ok so theres a list of the parts to be changed on 3si, so i know what needs to be done, but 60k is coming up and i'm pretty low on cash. How much have you guys paid for the 60k job? i'm really not sure what it should run. . . thanks
also, the list on 3si included a lot of stuff:
Water Pump MD972005 Air Conditioner belt MB879764 Alternator Belt MD187463 Power Steering Belt MD172376 Timing Belt MD193874 Tensioner MD319040 Timing Belt Tensioner Pulley MD140071 Timing Belt Idler Pulley DOHC MD319022 Power Steering Belt MD172376 Throttle Body Gasket MD180361 Intake Plenum Gasket MD143791 Spark Plugs(6) MS851336 Spark Plug Wires MD156560 Oil Oil Filter Air Filter
Does ALL of this really need to be replaced?
Old 02-07-2009, 07:36 PM
AutostradaVR4 AutostradaVR4 is offline
Re: 60k tune up
That list looks pretty conclusive. Timing belt, water pump, tensioner, tensioner pully, and idler pully are the most important things to do. If one of those go you'll be looking for a new motor. Gaskets, if they aint broke dont fix'em. The other belts are pretty cheap, so you might as well do them while you're in there. Plugs, wires, filters...use your judgement. If they're due for replacement you probably should.
If you do the work yourself you can get the parts for $300 or so. If you're planing on having it done at a shop, plan on $1K-$2K depending on where you take it. But, for the record, it's not a job i'd trust to just any corner garage.
It's really not that hard to do. There's plenty of write-ups on the web.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 02-07-2009, 07:42 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
Re: 60k tune up
The man thing that needs to be done when doing the 60k is your Tbelt and tentioner. When your in there its better to do your water pump cause if it fails you will have to take out the Tbelt anyways to fix it. Same with the Idler pulleys.
There are 2 ways I can think of for you to do it for less.
1. you can skip the Plugs, wires, TB gasket, Intake Gasket and even your other drive belts. I would keep the Water pump Tbelt Tentioner and Idlers for sure.
2. you can go with aftermarket parts. I wouldn't just go with the cheepest brand you can find... but I have had a lot of luck with some aftermarket stuff. I also sell a 60K kit for $280 if you are interested.
Jason
Old 02-07-2009, 09:31 PM
vr4choke's Avatar
Re: 60k tune up
i might be interested. what does your kit include?
Old 02-08-2009, 12:51 PM
jason_bet's Avatar
Re: 60k tune up
All the basic stuff.. Tbelt and Tentioner, Idlers, Water pump and gasket,2 Drive belts, and I will even through in some NGK copper plugs for free.
Jason
Old 02-08-2009, 05:55 PM
vr4choke's Avatar
Re: 60k tune up
that sounds great man.does it also have the power steering belt?and how would i go about purchasing your kit?
Old 02-08-2009, 07:08 PM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
Re: 60k tune up
you cant go wrong with buying jasons 60k kit, got mine from him as well as everything else i have for my car. great prices and jason is the man!
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Re: 60k tune up
Old 02-11-2009, 12:50 AM
jason_bet's Avatar
Re: 60k tune up
Here is a link to the product page. I don't have a picture on there but this is the kit-
http://www.pricematchedparts.com/pro...it-1599-0.html
Old 02-21-2009, 03:12 PM
3S Motorsports 3S Motorsports is offline
Re: 60k tune up
Just as a reference for people curious as to what a 3000gt specialty shop would charge for a 60K tuneup. WIth parts and Labor it is $850 with all stock OEM parts.
When doing a 60k always replace the water pump, t-belt, tenioner pulley, idler pulley and hydaulic tensioner.
All of those parts are potential problems if any of them break. And they all get replaced at the same time to avoid additional work down the line if one part breaks.
Someone mentioned that you will be looking for an engine if one of those break. That's just not true. You will probably need to replace some valves in your heads is all. not cheap, but not an entire motor.
The other parts, spark plugs, certain gaskets, belts, etc. are all parts that can be replaced at different times and when needed.
-Steve
-1995 VR4-3.5L Stroker Mod
World Record for 15G's @ 504awhp- Much more power soon to come!!!
-2005 Evo 8
-2008 Jetta 2.0t
-2005 Yamaha R1
-Ultralight Mosquito XEL (coming soon!)
Old 02-21-2009, 07:35 PM
Stealthee's Avatar
Stealthee Stealthee is offline
Your worst nightmare
Re: 60k tune up
Another thing people forget is the front crank seal. WOuldnt hurt to replace the cam seals too.
Both cheap and both easy to get to with the timing stuff out of the way.
Old 02-25-2009, 10:13 PM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
Re: 60k tune up
Make sure you do the idler tensioner and pulleys. My car is sitting right now because I neglected to make sure those were done when I had my t-belt replaced 8 months ago and one of those parts failed. It'll be a few weeks before I know if there is any significant damage because of it.
*crossing fingers for no motor work*
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 02-27-2009, 11:26 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: 60k tune up
pretty sure you have to remove the cam gears to replace the cam seals. yes its easy to the skilled mechanic, but not something i would just do b/c i'm in there.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
