Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 02-07-2009, 04:14 PM
Rod J Rod J is offline
94 passat electric windows
Just bought a 94 passat. Electric windows don't work. We were told it's either a fuse or relay. Where are they located? All ready looked on the fuse panel on the left and it wasn't there. Thanks for your help.
Old 02-22-2009, 07:51 PM
frescoraja frescoraja is offline
Re: 94 passat electric windows
not sure if you found this already, but hope it helps..
Fuse & Circuit Breaker Identification
1 - 10 Amp (Red) Left Headlight Low Beam
2 - 10 Amp (Red) Right Headlight Low Beam
3 - 10 Amp (Red) Instrument & License Lights
4 - 15 Amp (Blue) Rear Window Wiper/Washer, ABS
5 - 15 Amp (Blue) Windshield Wiper/Washer
6 - 30 Amp (Green) A/C, Fresh Air Fan
7 - 10 Amp (Red) Right Tail Light & Side Marker Light
8 - 10 Amp (Red) Left Taillight & Side Marker Light
9 - 20 Amp (Yellow) Rear Window Defroster, Mirror Heater
10 - 15 Amp (Blue) Fog Lamps
11 - 10 Amp (Red) Left Headlight High Beam & High Beam Indicator
12 - 10 Amp (Red) Right Headlight High Beam
13 - 10 Amp (Red) Horn
14 - 10 Amp (Red) Backup Lights
15 - 10 Amp (Red) Engine Electronics
16 - 15 Amp (Blue) Warning/Indicator Lights
17 - 10 Amp (Red) Turn Signals
18 - 20 Amp (Yellow) Fuel Pump
19 - 30 Amp (Green) A/C, Radiator Cooling Fan
20 - 10 Amp (Red) Brake Lights
21 - 15 Amp (Blue) Dome & Luggage Lamps, Cigar Lighter, Central Locking System, Multi-Function Indicator, Vanity Mirror, OBD Diagnostic
22 - 10 Amp (Red) Clock, Radio
See figure for Relay Panel Identification (1995-1996)
Courtesy of Volkswagen United States, Inc.
Fuse, Relay & Circuit Breaker Identification
1 - A/C Control Module Relay
2 - Rear Window Wiper/Washer Relay
3 - ECM Power Supply Relay
4 - Load Reduction Relay
5 - Engine Coolant Temperature/Low Coolant Relay
6 - Emergency Flasher Relay
7 - Headlight Washer Relay
8 - Washer/Wiper Intermittent Relay
9 - Radio/Parking Light Warning Buzzer Relay
10 - Fog Lamp/Parking Lamp Relay
11 - Dual Horn Relay
12 - Fuel Pump Relay
Additional Fuse Identification
WARNING: Always disconnect battery ground cable before servicing
"high-current fuses. It is recommended that "high-current"
fuses be replaced by a qualified technician.
NOTE: Located above Relays in passenger compartment.
30 Amp Fuse ABS Hydraulic Pump Relay
30 Amp Fuse ABS Main Relay
30 Amp Fuse A/C
30 Amp Fuse ABS System
20 Amp (Circuit Breaker) Power Windows
5 Amp Fuse Cruise Control
NOTE: Located on left side of engine compartment, near battery.
1 - 50 Amp Radiator Fan
Old 06-09-2009, 01:10 AM
Casper062103's Avatar
Casper062103 Casper062103 is offline
The relays are located under the back seat. Look for a pull loop they both lift right up.
