Go Back   Automotive Forums Car Chat > Buick > Regal
Old 02-07-2009, 03:29 PM
h20luby h20luby is offline
99 ls rear valve cover removal, tensioner assy?
does the tensioner assy have to be completely removed to get the rear valve cover off a 99 3800 ? wanting to change the valve cover gasket.
Old 02-09-2009, 12:20 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 ls rear valve cover removal, tensioner assy?
No. You can get to the one corner valve cover bolt without removing the tensioner assembly. There are 2 bolts on top and 4 on the bottom. Just enough clearance to get the valve cover out and back in with the new gasket.
Timeslip 08/12/06
AF Community Guidelines
Old 02-09-2009, 03:13 PM
thanks, I took the alternator off this weekend, and noticed there was only small amount of clearance between the alumimun bracket and top of valve cover.. didnt look like enough to get the cover off and be able to clear the rocker.
