Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Brakes and Suspension
Old 02-07-2009, 02:50 AM
boostjunkie333's Avatar
boostjunkie333 boostjunkie333 is offline
Send a message via AIM to boostjunkie333
rear brakes
hello, i have powerslot front rotors, and im about to do a rear drum-to-disc conversion, and the instructions call for snatching the rear discs off of a model eclipse that came with rear discs
so im wondering, are the front rotors the same as the ones id need for the back, or if i want powerslot rear discs will i need to buy the ones that would have came ont he rear of a 2g?
does this question make sense? lol
Hahn stage IV S16G-Portfueler w/400cc inj-1:1 Aeromotive FPR-Split sec fuel controller-Walbro 255lph FP-240cc inj-Hahn fuel mapper-JE pistons(8.1:1)-Total Seal rings-Eagle rods-ARP studs-AEM filter-C&R radiator-Hahn 3''downpipe & cat-Thermal Eng. 3''catback-LUK clutch & flywheel-Eibach springs-Eibach offset bushings-KYB GR2 struts-Strut bars-Lower rear tie bar-GReddy boost controller-Apexi T timer-Powerslot rotors-Gloshift gauges
Old 02-14-2009, 03:37 PM
Black99GST's Avatar
Black99GST Black99GST is offline
Send a message via AIM to Black99GST
Re: rear brakes
rear rotors are different. they need to accommodate for the hand brake.
Old 02-14-2009, 04:50 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
Re: rear brakes
You'll need rear rotors whether they are oem or aftermarket ones. They are a different size than the front rotors.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Old 02-15-2009, 09:16 PM
Re: rear brakes
thot so
i guess i could get away ordering powerslot rears from a gt or what-have-you and just put em on my rs since the how-to to this mod started with pulling from other eclipses so
sweet thanks
Old 02-15-2009, 09:46 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: rear brakes
Just wanted to show; you can see in the pic the size difference from the rotor to the wheel between the front rotor which I'm holding (and to the left) compared to the 2 on the top. The actual surface area of the rotors are different also.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-16-2009, 12:18 AM
Re: rear brakes
yeahhh ok thats what i had pictured in my head...
thanks for showing me and clearing it up
i have powerslot fronts, if i wnt powerslot rears i guess i should order a pair that would fit the rear of a 2g gt since thats where i would have gotten them if i hadnt bought ne wones for the conversion....and so the calipers will fit
Old 03-20-2009, 04:29 PM
Black99GST's Avatar
Re: rear brakes
i'm not to sure what it is you are asking because i forgot how to read like a 2nd grader... however, ordering the rear kit for the 2g GS/GST/GSX from Powerslot will provide you with the larger rear rotors you are looking for, as well as the caliper relocation brackets so that you can still use the OEM rear calipers without to much fuss.
Old 04-09-2009, 06:31 PM
Re: rear brakes
You forgot how to read like a second grader?
Im not quite sure I know what THAT means...
What im ultimately getting at is I own a gsx w/o an engine that im working on on the side, and I have powerslot front rotors on my rs now...had to convert the rear drums to rotors, I was curious if there were any big brake kits out there for the 2g that come with FOUR rotors instead of two like I keep finding...do they make a 4 piece kit for the 2g...im ready to order a brake kit for the gsx but can't find a full kit...do I have to buy two sets of two rotors? Piece it all together...
Old 04-14-2009, 12:04 PM
cantgo2fast's Avatar
cantgo2fast cantgo2fast is offline
Re: rear brakes
What he means by that is you might want to spell check your posts becasue its hard to read.
If your looking for a complete brake upgrade package you need the first two parts shown here
http://www.extremepsi.com/store/customer/search.php?veh=2G+DSM&cat=252&type=Brake+Kits
The first picture are the rear discs and the second picture is ar ethe fronts. If you alrady have the fronts then all your going to need are the rears.
These are for a 2g GSX/GST a 2g GT doesnt exist. I do not know if these brakes will fit on a GS/RS model
1995 GSX 2Gb bumper
Evo3 16g @18psi/walbro190/Greddy type S Bov/Dejon Intake/Bushur 3in DP/Custom 3in catback exhaust/FIC 750s/innovateLC1 WBO2/DSMLINK v2.5/Axxis ultimate pads/Aeromotive AFPR/ETS FMIC/Tein SS coilovers/ACT 2600/6puck/ACT flywheel/
Enkei RPF1 (15.6lbs) with 245/17 Dunlop Star Specs
Wish list:
CAMS
Old 04-14-2009, 01:38 PM
Re: rear brakes
thats exactly what i was looking for, thanks man!
