92 S10 4x4 4.3L Motor Mounts
What is the best way to replace engine mounts? Do I have to move the differential? I'd rather not if I can avoid it. Any tips, advice?
Re: 92 S10 4x4 4.3L Motor Mounts
I have never replaced mounts on one.
But. Have a look under there. If it is in the road move it. Sure makes oil pan come off a lot better. And may help get to mounts. Does your repair manual say what way to go? Good Luck
Just looking at the '92 manual and it looks the same as any Chevy V8 mount.
Support the truck properly on jackstands. Raise the engine a half inch or so but don't support the weight by the oilpan or front pulley. Remove the long bolt & nut in the mount that runs parallel to the crankshaft then remove the 3 mount to engine short bolts. Remove the old mount, install the new mount then start & tighten your bolts. There's no mention of removing the front differential, driveshaft or transfer case. |
Have a about 2 hr difference. S-10 blazer hits around 3.8 hrs for both front engine mounts. Hard to get to or someting in the road. That is why a person needs to craw under there and have a look around.
Wow, 3.8 hours!
I guess that's what the book meant when it said raise the car. Put it on a lift huh? |
Yes raise it up with a lift if you have one or jack it up and put it on stands. And for sure. Get under there and have a look around and see. There is something in the road or it is extra hard to do.
