Old 02-06-2009, 07:17 AM
brunnj brunnj is offline
Need help identifying this object
I have a 2002 Taurus with the 3.0L OHV engine. I have been having some trouble with the car since I purchased it. It started with misses at highway speeds and even had a pending code for misfire on cylinder 3. I replaced the plugs, wires and the cracked iginition coil so the misfire problem is now gone.
I am still having issues with lack of power at times and something that feels similar to a miss at highway speeds. The check engine light came on showing a code P1151. I took the vehicle to the dealership and let them check it. They said the upstream O2 sensor on bank 2 needed replacement. I replaced it. The car immediately drove better. The next day, all the same problems started again.
I believe my problem is fuel related and here's why. I connected my fuel pressure test guage to the test port and it showed 32 psi at idle. I purchased an Actron CP9180 scan tool and monitored some of the PCM PIDs at idle and it showed the fuel pressure at around 260-280kpa. My FSM gives two different fuel pressure specs for engine running: 50-56psi (350-380kpa) and 35-58psi (240-400kpa). I have replaced the fuel filter with no change in pressure. My question to you is what is the object shown in the photo. This is a picture of my fuel supply line with a silver round object connected inline. there are no wires or vacuum lines going to the object so my best guess is an inline fuel filter. The dealership could not identify this object and the only place it would even show up on their drawing was for a flex-fuel vehicle, which mine is not. Thanks for any help you can provide.
Old 02-06-2009, 07:30 AM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Need help identifying this object
Hmmm, so there's only a fuel line going in to one side and a line coming out, no vacuum, no electrical? I wonder if that's some sort of combination pulse dampner/anti-backflow valve? What was it called on the flex fuel vehicle? It doesn't look like a filter, but does have a shape characteristic of a valve with diaphragm cavity.
Have you tried getting the Ford part number off of it and searching for it online or through the dealer?
-Rod
Old 02-06-2009, 07:34 AM
-Rod
Yeah, the guy at the dealership tried to get a part number off of it but there wasn't a standard Ford part number. The object wasn't identified in their drawings but he called the line my fuel return line, which I know is not correct. I have the Electronic Ruturnless Fuel System on this car. There is no pressure regulator or fuel return line as I have a fuel rail pressure switch on the fuel rail (visible in the photo).
Old 02-06-2009, 10:54 AM
I just got through monitoring the PID's on my car again and I recorded the data. One thing really jumps out at me. According to the reference values listed in the 2002 Powertrain Control/Emissions Diagnosis manual, my engine load should be 10-20% at hot idle yet the actual value was constantly around 38%. I did not have the radio on or the heater blower. Also, the spark advance according the reference values should have been 24-30Deg. yet mine hovered around 18-21Deg., once dropping as low as 14Deg. Fuel presssure remained in the 267-282 kpa range.
Should I be concerned about the load or is that expected for an engine with 140,000 miles on it?
Old 02-06-2009, 12:48 PM
shorod's Avatar
SHO No Mo
I'm not sure how engine load is calculated by the PCM, so I'm not sure how much to concern yourself with those numbers. If I interpretted your initial post correctly, your misfire-like symptoms occur at highway speeds, you don't really have a concern with idle, correct? If so, you should be taking your readings in the same conditions where you have issues.
What are your short and long term fuel trim numbers? If your fuel pressure really is low, you'll probably see that in the STFT and LTFT numbers. I'd also expect you'd have a code pointing to a lean condition. Do your sensor 1 oxygen sensor voltages switch properly?
-Rod
Old 02-06-2009, 02:29 PM
-Rod
I'll have to dig through the data and post the numbers.
Old 02-06-2009, 03:24 PM
Thumbs up Re: Need help identifying this object
The scan tool recorded 35 frames of data. Here are the numbers you asked for on 15 of those frames. I can copy and paste all 35 frames of data if you want.
STFTRM1% LTFTRM1% STFTRM2% LTFTRM2% O2S11V O2S21V
.7 7.0 0.0 10.1 .750 .485
-2.2 6.2 0.7 10.9 .090 .035
.7 6.2 -1.0 9.3 .690 .380
.8 5.4 0.0 9.3 .470 .345
.8 6.2 2.3 9.3 .085 .030
.8 5.4 1.5 9.3 .085 .570
3.1 5.4 3.1 8.5 .770 .805
.7 5.4 0.0 9.3 .145 .675
3.1 5.4 2.3 8.5 .110 .705
4.6 5.4 3.9 8.5 .400 .785
.7 5.4 0.0 9.3 .100 .670
4.6 5.4 3.9 8.5 .695 .785
4.6 5.4 3.9 9.3 .830 .035
3.9 5.4 3.9 9.3 .655 .030
1.5 5.4 4.6 9.3 .125 .640
Let me know if you want me to copy and paste. Thanks.
Old 02-06-2009, 03:26 PM
It didn't space all my data out like I typed it out. It's a little difficult to read but all of the numbers should be under their respective columns.
Old 02-06-2009, 03:30 PM
Here's a portion of all of the data since my columns didn't work out as expected.
Recorded Data
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 783
CALC LOAD % 38.4
MAF FLOW GR/SE 4.59
COOLANT F 197
IAT F 73
IGN ADVANCE DE 14.0
ST FTRM1 % 0.7
LT FTRM1 % 7.0
ST FTRM2 % 0.0
LT FTRM2 % 10.1
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.750
ST FTRM11 % -3.4
O2S12 V 0.830
O2S21 V 0.485
ST FTRM21 % 0.0
O2S22 V 0.825
MIL DIST mi 0
OBD2 STAT CA
Frame -5 Time -4.0
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 769
CALC LOAD % 38.8
MAF FLOW GR/SE 4.42
COOLANT F 199
IAT F 73
IGN ADVANCE DE 15.0
ST FTRM1 % -2.2
LT FTRM1 % 6.2
ST FTRM2 % 0.7
LT FTRM2 % 10.9
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.090
ST FTRM11 % 0.7
O2S12 V 0.835
O2S21 V 0.035
ST FTRM21 % 0.7
O2S22 V 0.830
MIL DIST mi 0
OBD2 STAT CA
Frame -4 Time -3.2
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 758
CALC LOAD % 37.6
MAF FLOW GR/SE 4.26
COOLANT F 199
IAT F 73
IGN ADVANCE DE 16.0
ST FTRM1 % 0.7
LT FTRM1 % 6.2
ST FTRM2 % -1.0
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.690
ST FTRM11 % -1.0
O2S12 V 0.840
O2S21 V 0.380
ST FTRM21 % 0.8
O2S22 V 0.825
MIL DIST mi 0
OBD2 STAT CA
Frame -3 Time -2.4
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 750
CALC LOAD % 36.8
MAF FLOW GR/SE 4.26
COOLANT F 199
IAT F 73
IGN ADVANCE DE 16.0
ST FTRM1 % 0.8
LT FTRM1 % 5.4
ST FTRM2 % 0.0
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.470
ST FTRM11 % 0.0
O2S12 V 0.840
O2S21 V 0.345
ST FTRM21 % 0.7
O2S22 V 0.825
MIL DIST mi 0
OBD2 STAT CA
Frame -2 Time -1.6
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 767
CALC LOAD % 35.6
MAF FLOW GR/SE 4.15
COOLANT F 199
IAT F 73
IGN ADVANCE DE 16.5
ST FTRM1 % 0.8
LT FTRM1 % 6.2
ST FTRM2 % 2.3
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 2.3
O2S12 V 0.840
O2S21 V 0.030
ST FTRM21 % 2.3
O2S22 V 0.830
MIL DIST mi 0
OBD2 STAT CA
Frame -1 Time -0.8
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 730
CALC LOAD % 34.9
MAF FLOW GR/SE 3.98
COOLANT F 199
IAT F 73
IGN ADVANCE DE 17.5
ST FTRM1 % 0.8
LT FTRM1 % 5.4
ST FTRM2 % 1.5
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 285
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 2.3
O2S12 V 0.845
O2S21 V 0.570
ST FTRM21 % 1.5
O2S22 V 0.835
MIL DIST mi 0
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 724
CALC LOAD % 34.9
MAF FLOW GR/SE 3.87
COOLANT F 199
IAT F 71
IGN ADVANCE DE 18.5
ST FTRM1 % 3.1
LT FTRM1 % 5.4
ST FTRM2 % 3.1
LT FTRM2 % 8.5
VEH SPEED MPH 0
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.770
ST FTRM11 % 0.0
O2S12 V 0.840
O2S21 V 0.805
ST FTRM21 % 0.0
O2S22 V 0.840
MIL DIST mi 0
OBD2 STAT CA
Frame 1 Time 1.0
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 733
CALC LOAD % 34.1
MAF FLOW GR/SE 3.82
COOLANT F 199
IAT F 71
IGN ADVANCE DE 18.5
ST FTRM1 % 0.7
LT FTRM1 % 5.4
ST FTRM2 % 0.0
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.145
ST FTRM11 % 2.3
O2S12 V 0.840
O2S21 V 0.675
ST FTRM21 % 0.0
O2S22 V 0.845
MIL DIST mi 0
OBD2 STAT CA
Frame 2 Time 1.7
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 709
CALC LOAD % 34.1
MAF FLOW GR/SE 3.76
COOLANT F 199
IAT F 71
IGN ADVANCE DE 19.0
ST FTRM1 % 3.1
LT FTRM1 % 5.4
ST FTRM2 % 2.3
LT FTRM2 % 8.5
VEH SPEED MPH 0
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.110
ST FTRM11 % 4.6
O2S12 V 0.835
O2S21 V 0.705
ST FTRM21 % 0.0
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 3 Time 2.5
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 722
CALC LOAD % 33.7
MAF FLOW GR/SE 3.70
COOLANT F 199
IAT F 71
IGN ADVANCE DE 21.0
ST FTRM1 % 4.6
LT FTRM1 % 5.4
ST FTRM2 % 3.9
LT FTRM2 % 8.5
VEH SPEED MPH 0
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.400
ST FTRM11 % 3.9
O2S12 V 0.835
O2S21 V 0.785
ST FTRM21 % 0.7
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 4 Time 3.3
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 720
CALC LOAD % 33.7
MAF FLOW GR/SE 3.65
COOLANT F 199
IAT F 71
IGN ADVANCE DE 20.0
ST FTRM1 % 0.7
LT FTRM1 % 5.4
ST FTRM2 % 0.0
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % 4.6
O2S12 V 0.810
O2S21 V 0.670
ST FTRM21 % 0.7
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 5 Time 4.1
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 724
CALC LOAD % 33.7
MAF FLOW GR/SE 3.65
COOLANT F 199
IAT F 71
IGN ADVANCE DE 21.0
ST FTRM1 % 4.6
LT FTRM1 % 5.4
ST FTRM2 % 3.9
LT FTRM2 % 8.5
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.695
ST FTRM11 % 1.5
O2S12 V 0.830
O2S21 V 0.785
ST FTRM21 % 0.7
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 6 Time 4.9
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 724
CALC LOAD % 33.3
MAF FLOW GR/SE 3.59
COOLANT F 199
IAT F 71
IGN ADVANCE DE 21.0
ST FTRM1 % 4.6
LT FTRM1 % 5.4
ST FTRM2 % 3.9
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.830
ST FTRM11 % 2.3
O2S12 V 0.830
O2S21 V 0.035
ST FTRM21 % 3.9
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 7 Time 5.6
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 697
CALC LOAD % 33.3
MAF FLOW GR/SE 3.59
COOLANT F 199
IAT F 71
IGN ADVANCE DE 20.5
ST FTRM1 % 3.9
LT FTRM1 % 5.4
ST FTRM2 % 3.9
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.655
ST FTRM11 % 1.5
O2S12 V 0.820
O2S21 V 0.030
ST FTRM21 % 3.9
O2S22 V 0.855
MIL DIST mi 0
OBD2 STAT CA
Frame 8 Time 6.4
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 710
CALC LOAD % 32.9
MAF FLOW GR/SE 3.54
COOLANT F 199
IAT F 71
IGN ADVANCE DE 20.0
ST FTRM1 % 1.5
LT FTRM1 % 5.4
ST FTRM2 % 4.6
LT FTRM2 % 9.3
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.125
ST FTRM11 % 4.6
O2S12 V 0.820
O2S21 V 0.640
ST FTRM21 % 3.1
O2S22 V 0.855
MIL DIST mi 0
OBD2 STAT CA
Frame 9 Time 7.2
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 684
CALC LOAD % 33.7
MAF FLOW GR/SE 3.59
COOLANT F 199
IAT F 71
IGN ADVANCE DE 22.0
ST FTRM1 % 3.9
LT FTRM1 % 5.4
ST FTRM2 % 0.0
LT FTRM2 % 10.1
VEH SPEED MPH 0
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.690
ST FTRM11 % 1.5
O2S12 V 0.795
O2S21 V 0.785
ST FTRM21 % 0.7
O2S22 V 0.850
MIL DIST mi 0
OBD2 STAT CA
Frame 10 Time 8.0
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 717
CALC LOAD % 33.3
MAF FLOW GR/SE 3.54
COOLANT F 199
IAT F 71
IGN ADVANCE DE 20.5
ST FTRM1 % 1.5
LT FTRM1 % 6.2
ST FTRM2 % 0.0
LT FTRM2 % 10.1
VEH SPEED MPH 0
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.725
ST FTRM11 % 0.0
O2S12 V 0.820
O2S21 V 0.785
ST FTRM21 % 0.8
O2S22 V 0.860
MIL DIST mi 0
OBD2 STAT CA
Frame 11 Time 8.8
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 709
CALC LOAD % 33.3
MAF FLOW GR/SE 3.54
COOLANT F 199
IAT F 71
IGN ADVANCE DE 21.5
ST FTRM1 % 0.0
LT FTRM1 % 6.2
ST FTRM2 % 0.0
LT FTRM2 % 10.1
VEH SPEED MPH 0
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 3.1
O2S12 V 0.690
O2S21 V 0.275
ST FTRM21 % 1.5
O2S22 V 0.860
MIL DIST mi 0
OBD2 STAT CA
Old 02-10-2009, 02:43 PM
Here is the data from driving at highway speeds. I have not had a chance to review it myself. Thanks for your help.
Recorded Data
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 1273
CALC LOAD % 32.5
MAF FLOW GR/SE 6.20
COOLANT F 190
IAT F 46
IGN ADVANCE DE 38.5
ST FTRM1 % -6.3
LT FTRM1 % 3.1
ST FTRM2 % -6.3
LT FTRM2 % 7.0
VEH SPEED MPH 33
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.125
ST FTRM11 % -5.1
O2S12 V 0.775
O2S21 V 0.450
ST FTRM21 % -7.7
O2S22 V 0.790
MIL DIST mi 0
OBD2 STAT CA
Frame -5 Time -3.9
MIL STATUS OFF
ABSLT TPS % 18.8
ENG SPEED RPM 1078
CALC LOAD % 31.3
MAF FLOW GR/SE 5.03
COOLANT F 190
IAT F 46
IGN ADVANCE DE 32.0
ST FTRM1 % -4.6
LT FTRM1 % 2.3
ST FTRM2 % 0.8
LT FTRM2 % 8.5
VEH SPEED MPH 30
FUEL PRESS KPAG 264
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.085
ST FTRM11 % 1.5
O2S12 V 0.295
O2S21 V 0.050
ST FTRM21 % 3.1
O2S22 V 0.165
MIL DIST mi 0
OBD2 STAT CA
Frame -4 Time -3.1
MIL STATUS OFF
ABSLT TPS % 43.1
ENG SPEED RPM 2280
CALC LOAD % 92.5
MAF FLOW GR/SE 49.16
COOLANT F 192
IAT F 46
IGN ADVANCE DE 22.0
ST FTRM1 % 3.1
LT FTRM1 % 3.9
ST FTRM2 % 3.1
LT FTRM2 % 4.6
VEH SPEED MPH 34
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % 0.8
O2S12 V 0.745
O2S21 V 0.560
ST FTRM21 % -1.0
O2S22 V 0.560
MIL DIST mi 0
OBD2 STAT CA
Frame -3 Time -2.3
MIL STATUS OFF
ABSLT TPS % 63.5
ENG SPEED RPM 3438
CALC LOAD % 96.4
MAF FLOW GR/SE 81.06
COOLANT F 192
IAT F 44
IGN ADVANCE DE 23.0
ST FTRM1 % 2.3
LT FTRM1 % 3.9
ST FTRM2 % 6.2
LT FTRM2 % 4.6
VEH SPEED MPH 44
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.680
ST FTRM11 % -3.4
O2S12 V 0.285
O2S21 V 0.810
ST FTRM21 % 3.1
O2S22 V 0.250
MIL DIST mi 0
OBD2 STAT CA
Frame -2 Time -1.6
MIL STATUS OFF
ABSLT TPS % 52.9
ENG SPEED RPM 2914
CALC LOAD % 95.6
MAF FLOW GR/SE 63.17
COOLANT F 192
IAT F 44
IGN ADVANCE DE 23.5
ST FTRM1 % -3.4
LT FTRM1 % 3.9
ST FTRM2 % 2.3
LT FTRM2 % 4.6
VEH SPEED MPH 52
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.800
ST FTRM11 % 1.5
O2S12 V 0.340
O2S21 V 0.135
ST FTRM21 % -2.2
O2S22 V 0.540
MIL DIST mi 0
OBD2 STAT CA
Frame -1 Time -0.8
MIL STATUS OFF
ABSLT TPS % 44.7
ENG SPEED RPM 3121
CALC LOAD % 85.0
MAF FLOW GR/SE 59.91
COOLANT F 192
IAT F 44
IGN ADVANCE DE 26.5
ST FTRM1 % 0.8
LT FTRM1 % 3.9
ST FTRM2 % 2.3
LT FTRM2 % 4.6
VEH SPEED MPH 57
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.120
ST FTRM11 % 0.0
O2S12 V 0.710
O2S21 V 0.795
ST FTRM21 % 2.3
O2S22 V 0.295
MIL DIST mi 0
OBD2 STAT CA
Frame 0 Time 0.0
MIL STATUS OFF
ABSLT TPS % 35.2
ENG SPEED RPM 2068
CALC LOAD % 83.5
MAF FLOW GR/SE 35.32
COOLANT F 194
IAT F 44
IGN ADVANCE DE 24.5
ST FTRM1 % 1.5
LT FTRM1 % 3.9
ST FTRM2 % -2.2
LT FTRM2 % 4.6
VEH SPEED MPH 60
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.130
ST FTRM11 % 1.5
O2S12 V 0.760
O2S21 V 0.605
ST FTRM21 % 0.7
O2S22 V 0.345
MIL DIST mi 0
OBD2 STAT CA
Frame 1 Time 1.0
MIL STATUS OFF
ABSLT TPS % 34.9
ENG SPEED RPM 2138
CALC LOAD % 80.0
MAF FLOW GR/SE 35.93
COOLANT F 194
IAT F 46
IGN ADVANCE DE 24.0
ST FTRM1 % 1.5
LT FTRM1 % 3.9
ST FTRM2 % 0.0
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.290
ST FTRM11 % 2.3
O2S12 V 0.705
O2S21 V 0.800
ST FTRM21 % 0.7
O2S22 V 0.350
MIL DIST mi 0
OBD2 STAT CA
Frame 2 Time 1.8
MIL STATUS OFF
ABSLT TPS % 37.2
ENG SPEED RPM 2232
CALC LOAD % 69.4
MAF FLOW GR/SE 31.61
COOLANT F 195
IAT F 46
IGN ADVANCE DE 35.5
ST FTRM1 % 2.3
LT FTRM1 % 3.9
ST FTRM2 % -1.0
LT FTRM2 % 4.6
VEH SPEED MPH 63
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % -2.2
O2S12 V 0.715
O2S21 V 0.610
ST FTRM21 % 2.3
O2S22 V 0.545
MIL DIST mi 0
OBD2 STAT CA
Frame 3 Time 2.5
MIL STATUS OFF
ABSLT TPS % 31.3
ENG SPEED RPM 2270
CALC LOAD % 65.4
MAF FLOW GR/SE 29.90
COOLANT F 195
IAT F 46
IGN ADVANCE DE 36.0
ST FTRM1 % 3.1
LT FTRM1 % 3.9
ST FTRM2 % 0.7
LT FTRM2 % 4.6
VEH SPEED MPH 65
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.120
ST FTRM11 % 0.8
O2S12 V 0.720
O2S21 V 0.750
ST FTRM21 % 0.0
O2S22 V 0.635
MIL DIST mi 0
OBD2 STAT CA
Frame 4 Time 3.3
MIL STATUS OFF
ABSLT TPS % 29.4
ENG SPEED RPM 2258
CALC LOAD % 61.9
MAF FLOW GR/SE 27.35
COOLANT F 194
IAT F 46
IGN ADVANCE DE 39.5
ST FTRM1 % 0.0
LT FTRM1 % 3.9
ST FTRM2 % 1.5
LT FTRM2 % 3.9
VEH SPEED MPH 64
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.800
ST FTRM11 % 1.5
O2S12 V 0.690
O2S21 V 0.795
ST FTRM21 % -1.0
O2S22 V 0.390
MIL DIST mi 0
OBD2 STAT CA
Frame 5 Time 4.1
MIL STATUS OFF
ABSLT TPS % 34.1
ENG SPEED RPM 2229
CALC LOAD % 73.3
MAF FLOW GR/SE 33.83
COOLANT F 192
IAT F 46
IGN ADVANCE DE 31.5
ST FTRM1 % -2.2
LT FTRM1 % 3.9
ST FTRM2 % 1.5
LT FTRM2 % 4.6
VEH SPEED MPH 63
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.790
ST FTRM11 % 0.7
O2S12 V 0.675
O2S21 V 0.620
ST FTRM21 % -3.4
O2S22 V 0.640
MIL DIST mi 0
OBD2 STAT CA
Frame 6 Time 4.9
MIL STATUS OFF
ABSLT TPS % 32.5
ENG SPEED RPM 2248
CALC LOAD % 65.8
MAF FLOW GR/SE 30.01
COOLANT F 190
IAT F 46
IGN ADVANCE DE 36.5
ST FTRM1 % -2.2
LT FTRM1 % 3.9
ST FTRM2 % 2.3
LT FTRM2 % 4.6
VEH SPEED MPH 65
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.775
ST FTRM11 % -4.6
O2S12 V 0.710
O2S21 V 0.075
ST FTRM21 % -3.4
O2S22 V 0.660
MIL DIST mi 0
OBD2 STAT CA
Frame 7 Time 5.7
MIL STATUS OFF
ABSLT TPS % 27.4
ENG SPEED RPM 2278
CALC LOAD % 54.5
MAF FLOW GR/SE 22.75
COOLANT F 188
IAT F 46
IGN ADVANCE DE 44.0
ST FTRM1 % 0.0
LT FTRM1 % 3.9
ST FTRM2 % 0.8
LT FTRM2 % 3.9
VEH SPEED MPH 65
FUEL PRESS KPAG 267
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.595
ST FTRM11 % -1.0
O2S12 V 0.710
O2S21 V 0.090
ST FTRM21 % -2.2
O2S22 V 0.645
MIL DIST mi 0
OBD2 STAT CA
Frame 8 Time 6.4
MIL STATUS OFF
ABSLT TPS % 20.0
ENG SPEED RPM 2280
CALC LOAD % 34.1
MAF FLOW GR/SE 13.12
COOLANT F 188
IAT F 46
IGN ADVANCE DE 41.5
ST FTRM1 % -7.7
LT FTRM1 % 0.0
ST FTRM2 % -1.0
LT FTRM2 % 3.9
VEH SPEED MPH 65
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.395
ST FTRM11 % 0.0
O2S12 V 0.680
O2S21 V 0.610
ST FTRM21 % 0.8
O2S22 V 0.160
MIL DIST mi 0
OBD2 STAT CA
Frame 9 Time 7.2
MIL STATUS OFF
ABSLT TPS % 20.7
ENG SPEED RPM 2333
CALC LOAD % 39.2
MAF FLOW GR/SE 18.05
COOLANT F 186
IAT F 46
IGN ADVANCE DE 39.5
ST FTRM1 % -4.6
LT FTRM1 % 0.0
ST FTRM2 % 1.5
LT FTRM2 % 2.3
VEH SPEED MPH 64
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.090
ST FTRM11 % 0.0
O2S12 V 0.645
O2S21 V 0.820
ST FTRM21 % -4.6
O2S22 V 0.350
MIL DIST mi 0
OBD2 STAT CA
Frame 10 Time 8.0
MIL STATUS OFF
ABSLT TPS % 21.1
ENG SPEED RPM 2286
CALC LOAD % 40.3
MAF FLOW GR/SE 13.51
COOLANT F 185
IAT F 46
IGN ADVANCE DE 41.5
ST FTRM1 % -3.4
LT FTRM1 % 0.0
ST FTRM2 % -5.1
LT FTRM2 % 2.3
VEH SPEED MPH 63
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.760
ST FTRM11 % -1.0
O2S12 V 0.635
O2S21 V 0.340
ST FTRM21 % 1.5
O2S22 V 0.635
MIL DIST mi 0
OBD2 STAT CA
Frame 11 Time 8.8
MIL STATUS OFF
ABSLT TPS % 22.7
ENG SPEED RPM 2238
CALC LOAD % 42.3
MAF FLOW GR/SE 16.99
COOLANT F 186
IAT F 46
IGN ADVANCE DE 46.0
ST FTRM1 % 0.8
LT FTRM1 % 0.0
ST FTRM2 % 2.3
LT FTRM2 % 0.7
VEH SPEED MPH 63
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.540
ST FTRM11 % -4.9
O2S12 V 0.630
O2S21 V 0.795
ST FTRM21 % 1.5
O2S22 V 0.490
MIL DIST mi 0
OBD2 STAT CA
Frame 12 Time 9.6
MIL STATUS OFF
ABSLT TPS % 21.5
ENG SPEED RPM 2235
CALC LOAD % 36.4
MAF FLOW GR/SE 14.34
COOLANT F 186
IAT F 46
IGN ADVANCE DE 46.5
ST FTRM1 % -4.9
LT FTRM1 % 0.7
ST FTRM2 % 0.0
LT FTRM2 % 3.9
VEH SPEED MPH 63
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.075
ST FTRM11 % 3.1
O2S12 V 0.540
O2S21 V 0.810
ST FTRM21 % 1.5
O2S22 V 0.295
MIL DIST mi 0
OBD2 STAT CA
Frame 13 Time 10.3
MIL STATUS OFF
ABSLT TPS % 21.9
ENG SPEED RPM 2239
CALC LOAD % 40.0
MAF FLOW GR/SE 15.50
COOLANT F 188
IAT F 46
IGN ADVANCE DE 46.5
ST FTRM1 % -4.6
LT FTRM1 % 0.0
ST FTRM2 % -2.2
LT FTRM2 % 2.3
VEH SPEED MPH 63
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.785
ST FTRM11 % 0.0
O2S12 V 0.595
O2S21 V 0.800
ST FTRM21 % 0.7
O2S22 V 0.285
MIL DIST mi 0
OBD2 STAT CA
Frame 14 Time 11.1
MIL STATUS OFF
ABSLT TPS % 21.9
ENG SPEED RPM 2225
CALC LOAD % 41.1
MAF FLOW GR/SE 16.72
COOLANT F 188
IAT F 46
IGN ADVANCE DE 45.5
ST FTRM1 % 1.5
LT FTRM1 % 0.7
ST FTRM2 % 3.1
LT FTRM2 % 2.3
VEH SPEED MPH 63
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.765
ST FTRM11 % -1.0
O2S12 V 0.445
O2S21 V 0.055
ST FTRM21 % 3.9
O2S22 V 0.175
MIL DIST mi 0
OBD2 STAT CA
Frame 15 Time 11.9
MIL STATUS OFF
ABSLT TPS % 28.6
ENG SPEED RPM 2180
CALC LOAD % 62.7
MAF FLOW GR/SE 27.13
COOLANT F 190
IAT F 46
IGN ADVANCE DE 37.5
ST FTRM1 % -1.0
LT FTRM1 % 3.9
ST FTRM2 % 1.5
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.680
ST FTRM11 % 0.8
O2S12 V 0.695
O2S21 V 0.790
ST FTRM21 % 2.3
O2S22 V 0.625
MIL DIST mi 0
OBD2 STAT CA
Frame 16 Time 12.7
MIL STATUS OFF
ABSLT TPS % 32.9
ENG SPEED RPM 2167
CALC LOAD % 71.7
MAF FLOW GR/SE 31.17
COOLANT F 190
IAT F 46
IGN ADVANCE DE 33.0
ST FTRM1 % 2.3
LT FTRM1 % 3.9
ST FTRM2 % 0.7
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.510
ST FTRM11 % 2.3
O2S12 V 0.755
O2S21 V 0.095
ST FTRM21 % -2.2
O2S22 V 0.685
MIL DIST mi 0
OBD2 STAT CA
Frame 17 Time 13.5
MIL STATUS OFF
ABSLT TPS % 30.5
ENG SPEED RPM 2158
CALC LOAD % 65.8
MAF FLOW GR/SE 28.18
COOLANT F 192
IAT F 46
IGN ADVANCE DE 36.5
ST FTRM1 % 0.7
LT FTRM1 % 3.9
ST FTRM2 % -2.2
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.760
ST FTRM11 % 4.6
O2S12 V 0.735
O2S21 V 0.815
ST FTRM21 % -3.4
O2S22 V 0.275
MIL DIST mi 0
OBD2 STAT CA
Frame 18 Time 14.2
MIL STATUS OFF
ABSLT TPS % 34.5
ENG SPEED RPM 2184
CALC LOAD % 75.6
COOLANT F 192
IAT F 46
IGN ADVANCE DE 30.0
ST FTRM1 % -2.2
LT FTRM1 % 3.9
ST FTRM2 % -4.6
LT FTRM2 % 4.6
VEH SPEED MPH 63
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.800
ST FTRM11 % 0.0
O2S12 V 0.740
O2S21 V 0.115
ST FTRM21 % 3.1
O2S22 V 0.710
MIL DIST mi 0
OBD2 STAT CA
Frame 19 Time 15.0
MIL STATUS OFF
ABSLT TPS % 32.9
ENG SPEED RPM 2228
CALC LOAD % 69.4
MAF FLOW GR/SE 30.84
COOLANT F 194
IAT F 46
IGN ADVANCE DE 36.0
ST FTRM1 % 0.7
LT FTRM1 % 3.9
ST FTRM2 % 2.3
LT FTRM2 % 3.9
VEH SPEED MPH 63
FUEL PRESS KPAG 273
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.785
ST FTRM11 % -1.0
O2S12 V 0.730
O2S21 V 0.180
ST FTRM21 % -3.4
O2S22 V 0.680
MIL DIST mi 0
OBD2 STAT CA
Frame 20 Time 15.8
MIL STATUS OFF
ABSLT TPS % 25.4
ENG SPEED RPM 2225
CALC LOAD % 51.3
MAF FLOW GR/SE 20.81
COOLANT F 194
IAT F 46
IGN ADVANCE DE 44.0
ST FTRM1 % -3.4
LT FTRM1 % 3.1
ST FTRM2 % -4.6
LT FTRM2 % 3.9
VEH SPEED MPH 63
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.770
ST FTRM11 % 0.0
O2S12 V 0.705
O2S21 V 0.080
ST FTRM21 % -4.6
O2S22 V 0.650
MIL DIST mi 0
OBD2 STAT CA
Frame 21 Time 16.6
MIL STATUS OFF
ABSLT TPS % 25.8
ENG SPEED RPM 2229
CALC LOAD % 56.4
MAF FLOW GR/SE 23.08
COOLANT F 194
IAT F 46
IGN ADVANCE DE 43.5
ST FTRM1 % 0.7
LT FTRM1 % 3.1
ST FTRM2 % -2.2
LT FTRM2 % 3.1
VEH SPEED MPH 63
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.130
ST FTRM11 % 0.8
O2S12 V 0.680
O2S21 V 0.655
ST FTRM21 % 1.5
O2S22 V 0.355
MIL DIST mi 0
OBD2 STAT CA
Frame 22 Time 17.4
MIL STATUS OFF
ABSLT TPS % 24.7
ENG SPEED RPM 2250
CALC LOAD % 48.6
MAF FLOW GR/SE 19.54
COOLANT F 192
IAT F 46
IGN ADVANCE DE 45.0
ST FTRM1 % 0.0
LT FTRM1 % 1.5
ST FTRM2 % -2.2
LT FTRM2 % 1.5
VEH SPEED MPH 64
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.115
ST FTRM11 % 1.5
O2S12 V 0.660
O2S21 V 0.775
ST FTRM21 % 2.3
O2S22 V 0.440
MIL DIST mi 0
OBD2 STAT CA
Frame 23 Time 18.2
MIL STATUS OFF
ABSLT TPS % 23.9
ENG SPEED RPM 2257
CALC LOAD % 46.2
MAF FLOW GR/SE 18.43
COOLANT F 190
IAT F 46
IGN ADVANCE DE 45.5
ST FTRM1 % 1.5
LT FTRM1 % 0.7
ST FTRM2 % -2.2
LT FTRM2 % 1.5
VEH SPEED MPH 64
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.100
ST FTRM11 % -1.0
O2S12 V 0.650
O2S21 V 0.160
ST FTRM21 % -1.0
O2S22 V 0.380
MIL DIST mi 0
OBD2 STAT CA
Frame 24 Time 18.9
MIL STATUS OFF
ABSLT TPS % 22.3
ENG SPEED RPM 2259
CALC LOAD % 36.0
MAF FLOW GR/SE 14.06
COOLANT F 188
IAT F 46
IGN ADVANCE DE 46.0
ST FTRM1 % -7.7
LT FTRM1 % 0.0
ST FTRM2 % -9.2
LT FTRM2 % 4.6
VEH SPEED MPH 64
FUEL PRESS KPAG 285
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.055
ST FTRM11 % -2.2
O2S12 V 0.685
O2S21 V 0.790
ST FTRM21 % -6.3
O2S22 V 0.690
MIL DIST mi 0
OBD2 STAT CA
Frame 25 Time 19.7
MIL STATUS OFF
ABSLT TPS % 19.2
ENG SPEED RPM 2089
CALC LOAD % 19.2
MAF FLOW GR/SE 6.09
COOLANT F 186
IAT F 46
IGN ADVANCE DE 36.5
ST FTRM1 % 7.8
LT FTRM1 % -4.6
ST FTRM2 % 5.4
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 264
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.055
ST FTRM11 % 8.5
O2S12 V 0.785
O2S21 V 0.765
ST FTRM21 % 4.6
O2S22 V 0.795
MIL DIST mi 0
OBD2 STAT CA
Frame 26 Time 20.5
MIL STATUS OFF
ABSLT TPS % 21.1
ENG SPEED RPM 2196
CALC LOAD % 28.6
MAF FLOW GR/SE 9.96
COOLANT F 185
IAT F 46
IGN ADVANCE DE 39.5
ST FTRM1 % 0.0
LT FTRM1 % 1.5
ST FTRM2 % -1.0
LT FTRM2 % 2.3
VEH SPEED MPH 60
FUEL PRESS KPAG 270
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.060
ST FTRM11 % 0.7
O2S12 V 0.735
O2S21 V 0.730
ST FTRM21 % 1.5
O2S22 V 0.725
MIL DIST mi 0
OBD2 STAT CA
Frame 27 Time 21.3
MIL STATUS OFF
ABSLT TPS % 28.2
ENG SPEED RPM 2307
CALC LOAD % 61.9
MAF FLOW GR/SE 29.67
COOLANT F 185
IAT F 46
IGN ADVANCE DE 37.5
ST FTRM1 % 3.1
LT FTRM1 % 3.9
ST FTRM2 % 1.5
LT FTRM2 % 4.6
VEH SPEED MPH 60
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.765
ST FTRM11 % -1.0
O2S12 V 0.650
O2S21 V 0.830
ST FTRM21 % 3.1
O2S22 V 0.500
MIL DIST mi 0
OBD2 STAT CA
Frame 28 Time 22.1
MIL STATUS OFF
ABSLT TPS % 38.0
ENG SPEED RPM 2149
CALC LOAD % 87.8
MAF FLOW GR/SE 39.14
COOLANT F 185
IAT F 46
IGN ADVANCE DE 22.5
ST FTRM1 % 0.8
LT FTRM1 % 3.9
ST FTRM2 % 2.3
LT FTRM2 % 4.6
VEH SPEED MPH 62
FUEL PRESS KPAG 282
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.805
ST FTRM11 % -3.4
O2S12 V 0.640
O2S21 V 0.810
ST FTRM21 % 0.7
O2S22 V 0.570
MIL DIST mi 0
OBD2 STAT CA
Frame 29 Time 22.8
MIL STATUS OFF
ABSLT TPS % 35.2
ENG SPEED RPM 2206
CALC LOAD % 79.6
MAF FLOW GR/SE 35.60
COOLANT F 186
IAT F 44
IGN ADVANCE DE 28.0
ST FTRM1 % -1.0
LT FTRM1 % 3.9
ST FTRM2 % -2.2
LT FTRM2 % 4.6
VEH SPEED MPH 63
FUEL PRESS KPAG 279
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.790
ST FTRM11 % -2.2
O2S12 V 0.720
O2S21 V 0.085
ST FTRM21 % 3.1
O2S22 V 0.695
MIL DIST mi 0
OBD2 STAT CA
Frame 30 Time 23.6
MIL STATUS OFF
ABSLT TPS % 32.5
ENG SPEED RPM 2224
CALC LOAD % 67.4
MAF FLOW GR/SE 30.12
COOLANT F 188
IAT F 46
IGN ADVANCE DE 35.0
ST FTRM1 % 0.8
LT FTRM1 % 3.9
ST FTRM2 % 0.8
LT FTRM2 % 4.6
VEH SPEED MPH 63
FUEL PRESS KPAG 276
FUEL SYS 1 CLSD
FUEL SYS 2 N/A
O2S11 V 0.445
ST FTRM11 % -2.2
O2S12 V 0.735
O2S21 V 0.510
ST FTRM21 % -3.4
O2S22 V 0.665
MIL DIST mi 0
OBD2 STAT CA
Frame 31 Time 24.4
MIL STATUS($10) ---
ABSLT TPS($10) ---
ENG SPEED($10) ---
CALC LOAD($10) ---
MAF FLOW($10) ---
COOLANT($10) ---
IAT($10) ---
IGN ADVANCE($10) ---
ST FTRM1($10) ---
LT FTRM1($10) ---
ST FTRM2 % -100.6
LT FTRM2 % -97.9
VEH SPEED MPH 3
FUEL PRESS KPAG 30
FUEL SYS 1 OPEN2
FUEL SYS 2 CLSD1
O2S11 V 0.145
ST FTRM11 % -73.1
O2S12 V 0.265
O2S21 V 0.275
ST FTRM21 % -51.0
O2S22 V 0.525
MIL DIST mi 40546
OBD2 STAT N/A
Frame -1 Time-131.7
MIL STATUS OFF
ABSLT TPS % 0.0
ENG SPEED RPM 0
CALC LOAD % 0.0
MAF FLOW GR/SE 0.00
COOLANT F -40
IAT F -40
IGN ADVANCE DE -64.6
ST FTRM1 % -100.6
LT FTRM1 % -100.6
ST FTRM2 % -100.6
LT FTRM2 % -100.6
VEH SPEED MPH 0
FUEL PRESS KPAG 0
FUEL SYS 1 N/A
FUEL SYS 2 N/A
O2S11 V 0.000
ST FTRM11 % -100.6
O2S12 V 0.000
O2S21 V 0.000
ST FTRM21 % -100.6
O2S22 V 0.000
MIL DIST mi 0
OBD2 STAT N/A
Frame 0 Time-131.6
Old 02-10-2009, 10:02 PM
shorod's Avatar
SHO No Mo
That's a lot to read through. Your 6 Feb data for the fuel trim numbers seems rather high for the long term side. It also appears pretty erratic. However, the fuel trim numbers of today's data seem pretty reasonable and consistent. The last few frames though appear to be corrupted and should be thrown out.
Myabe instead of posting all the data, you could plot the fuel trim numbers from the data posted on the 6th and a separate plot for the data on the 10th to see how they compare. While none of the fuel trim numbers (I only scanned the data, didn't study it all) appeared outside of acceptable parameters, the highway data from today seems to be higher than typical.
-Rod
Old 02-11-2009, 06:47 AM
-Rod
The data from the last drive cycle was corrupted as well. I'm not sure what could be causing that.
Old 02-11-2009, 09:08 AM
-Rod
I've noticed that the long term fuel trim numbers are consistently higher for bank 2 than they are for bank 1. I wonder if replacing the upstream O2 sensor for bank 1 would help any. It would be nice if I knew how load was calculated by the PCM. I reset the check engine light (code P1151) and it has not come back on even though I continue to experience drivability concerns.
Old 02-11-2009, 08:29 PM
shorod's Avatar
SHO No Mo
I just looked at a Ford OBD-II description document for 1998. There are a lot of references to engine load and the various ranges for the load in order for certain OBD-II monitors to be used, but nothing that explains how that engine load is calculated.
You might try a Google search (I have not).
-Rod
