Old 02-06-2009, 07:58 AM
DEEPEE DEEPEE is offline
Reverse Tire Direction (Rotating Tires)
Does anyone reverse their tire rotation when rotating tires? These are mud grips so towards the end of the 6,000 miles when it's time to rotate, the lugs start to cup somewhat. The front end alignment is good, front end is all tight, it's just a mud grip thing. I always do the rotation by moving the front tires straight to the back and the back to the front. I heard some people say never do the cross pattern rotation which will change the direction of travel and might mess up the belts inside the tire. These are Firestone Destination M/T LT/285's. Thanks
Old 02-06-2009, 09:04 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Reverse Tire Direction (Rotating Tires)
Best to only post in one forum.
You have the same post in CK forum.
Old school was only front to rear on steel belt.
Newer tires always check with a good tire shop or the tire manf. rep.
Rear tire sould wear smooth.
If they are cupping out you have a alignment or inflation or faulty tire problem.
Have you been running the correct air pressure in them?
MT
Old 02-06-2009, 10:46 AM
j cAT j cAT is offline
On my silverado I have been rotating by the instructions in the owners manual and the tire shop that I go to..this would NOT be simply front to rear but criss crossing the front /rear...
the tires I use are firestone steeltex tires and these are the same that I ordered when I purchased the vehicle...at 92,ooomi I replaced with the same tire...rotate every 10-13,ooomi.
I suspect you have raised your vehicle and also have a shock/suspension problem if you have cupping...
Old 02-14-2009, 09:14 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
radial tires are supposed to be cross rotated. the only exempt is directional tires. they should have clear stamped direction arrow on the sidewall.
I am not quite sure which lugs are you referring to, obviously, not lug nuts? But just in case, lug nuts must be the ones that have spinning washers built in.
Old 02-14-2009, 11:45 PM
kahjdh's Avatar
kahjdh kahjdh is offline
No, lugs in the treads, aggressive tires.
I think that if they are not directional there wouldnt be a problem if they were cross rotated but i could be wrong.
ASE Master Certified before the age of 20
Current Cars:
2001 Chevy Silverado 1500 Z71 5.3L
1996 Acura Integra LS B18 1.8L
Past Cars:
1990 Buick Estate Wagon 5.0L
1987 Chevy S10 2.5L Tec Four
1995 Pontiac Grand Am 2.3 Quad 4
1996 Jeep Grand Cherokee Limited 5.2L AWD
1991 Ford Tempo L 2.3L
1992 Buick LeSabre 3.8L
1997 Buick Century 3.1L
1996 Lumina APV GT 3.4L
2006 Ford Escape 3.0L XLT
