Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 02-05-2009, 07:14 PM
mtdewman800 mtdewman800 is offline
trailer hitch help
I have a 1994 chevy tahoe lt the down size and I cant find a trailer hitch to fit.Please help
Old 02-05-2009, 08:11 PM
777stickman 777stickman is offline
Re: trailer hitch help
I would have to say your best bet is to call local trailer hitch places and speak with them.
They have the knowledge to fit you with a hitch that will meet your towing needs.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 02-05-2009, 08:57 PM
roadrunner2 roadrunner2 is offline
FWIW, the '95 Tahoe has a trailer capacity of 7k lbs (trailer/hitch and load).
To be on the safe side, reduce that to 5k lbs. Class 111 hitch. Check the Reese site it MAY show what you can use.
Whatever you find, make sure you add an aftermarket trans cooler and brake controller.
I use a Prodigy and I find it one of the best,
The problem with doing nothing is not knowing when you're finished.
Old 02-05-2009, 09:09 PM
To add, Not knowing what the gross weight of your trailer will be I can't steer you in the right direction, may be just a little prod.
If you'll have less than 2000lbs towed load with a 150-200lb tongue weight you will likely not need a weight distribution hitch. If more, you will need one.
If you haven't towed before or for a long time, you might want to read the following site.
Be safe.
http://www.rvtowingtips.com
