Go Back   Automotive Forums Car Chat > Chevrolet > Lumina APV
Old 02-05-2009, 05:29 PM
dmsmat dmsmat is offline
1996 Chevy Lumina APV heating problem
my van was defrosting fine and heating fine. Then it would go off every now and then, now I am not getting any heat blowing out at all. What could be the problem?
Old 02-06-2009, 04:33 PM
LMP's Avatar
LMP LMP is offline
Re: 1996 Chevy Lumina APV heating problem
What do you mean exactly? fan works and just cold air, no heat ?....or fan would not blow, dead blower, no air at all..?
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
Old 02-06-2009, 09:16 PM
I mean no air is coming out at all, no cold no hot. Not sure if it's the blower motor or not
Old 02-07-2009, 01:07 AM
discnik discnik is offline
When you place the fan select to "HI" can you here or feel the blower motor running ? It is under the right side dash.
Old 02-07-2009, 03:00 AM
LMP's Avatar
LMP LMP is offline
Test blower motor by connecting 12V direct to the motor connector, in engine compartment: 1996 plastic body must have kept this original configuration:
If motor ok, check high speed relay and socket . (all speeds are fed through the high speed relay).
