Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 02-05-2009, 12:53 PM
Eclipser80 Eclipser80 is offline
Send a message via AIM to Eclipser80
not sure if its anything but..
I was working on my current major problem.. found in another thread...but while i was working i started to smell something sweet i eventually found out it was my exhaust. is it a problem or anything at all if my exhaust smells really sweet, doesn't that mean its running rich?
1995 Mitsubishi Eclipse GS Non-turbo
Old 02-05-2009, 01:24 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: not sure if its anything but..
Coolant usually smells sweet when hot so you should check there. Is the smell coming from the end of the exhaust itself or are you smelling it underneath?
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 02-05-2009, 02:15 PM
end of the exhaust, and yea we are having problems with the coolant. I think i heard my dad say the tube leading from the resevoir to the radiator is vaccumed closed.. like nothing is there but air being sucks causeing the hose to depress.
Old 02-05-2009, 03:47 PM
david-b's Avatar
Dave is THAT guy
There is no direct hose from the radiator to the reservoir. It goes from the radiator to the thermostat housing and then it overflows into reservoir if need be. That system is vacuum-like, but only usually when the car is shut off.
So what exactly is the problem with the coolant and what hose is 'depressing'?
75 Monte Carlo
Old 02-05-2009, 06:08 PM
I believe its the upper hose. not sure..and when the car is running theres nothing in it so it depresses slightly.
