Old 02-05-2009, 11:07 AM
theirrigationguy theirrigationguy is offline
1992 S10 blazer problem
I own a 1992 S10 Blazer. On cold mornings it takes 5 minutes to start. in the evenings when i go home from work, (work 10 hours) it takes about 5 minutes to start. after i get to work and i get home (after blazer is warmed up) it will start up immediately.
In the mornings i can hear the fuel pump running for about 5 seconds before i turn the engine over. if the truck does not start up i will turn the ignition off but i can still hear the fuel pump running for about 5-7 seconds after the ignition is off.
any suggestions?
thanks for your time
Old 02-05-2009, 12:42 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1992 S10 blazer problem
Any codes?
How many mile since a good tune up?
Check fuel filter and fuel pressure?
Postback fuel pressure readings.
MT
Old 02-14-2009, 08:02 AM
krackerjack9 krackerjack9 is offline
Im having the same problem, I have to press the accelerator to the floor crank a second or 2 , then crank again then it will start. I did have my fuel regulator replaced about a year ago and this seems almost like the same symptoms, but my fuel mileage is still in the 20 to 21 mpg range.
I did take the manifold off to see if I could see a leak but didnt notice anything. Any thoughts
Old 02-14-2009, 08:59 AM
MT-2500's Avatar
AF - Advisor
Best to start a New Thread on yours.
MT
Old 02-19-2009, 12:50 PM
good tune up the other day.
i will get the pressure readings asap (must buy one).
i plan to change the fuel filter this weekend. (working many hours)
refresh my memory....how do you relieve the pressure from the fuel filter before i change it?
thanks again for your answers.
Old 02-19-2009, 02:08 PM
MT-2500's Avatar
AF - Advisor
You can drive it till it runs out of fuel or pull fuel pump fuse and run till it quits or let it sit over night.
But you will always get some fuel leakage at the fuel filter and line.
Wear eye protection and ear plugs to be on safe side and no smoking or open flames or hot drop lights or garage heaters close to it.
I had a son-law get his ear full of gas changing fuel filter one time.
He squealed like a panther and made a big streak for the swimming pool and jumped in.
And was still squealing a hr. later.
MT
