Go Back   Automotive Forums Car Chat > Saturn > Vue
Old 02-05-2009, 11:45 AM
justinb10 justinb10 is offline
Daytime Running Lights
In my 2003 Vue, the daytime running lights indicator on the dashboard flashes and then shuts off. The daytime running lights aren't working. Also when I use the keyless entry to lock/unlock the vehicle, the lights won't flash. I checked the fuse under the hood in the fuse block, it's a good fuse.
Any ideas why they aren't working? The headlights work at night without any problems, as well as the fog lights.
2007 Pontiac G6
2000 Oldsmobile Bravada
1998 Pontiac Grand Prix GT
2002 Ford F-150
2007 Ford F-150
1993 Chrysler New Yorker Salon
Old 02-07-2009, 11:00 PM
grfnkl's Avatar
grfnkl grfnkl is offline
Send a message via AIM to grfnkl
Re: Daytime Running Lights
if i remember correctly for the vues the DRL's use the highbeams.... have you checked all your lights, low beams and high beams. I know on some models if you have a burnt out bulb it will cause this. if not it sounds as if your DRL relay is going bad. I would start with these two first.
Old 03-05-2009, 03:09 PM
saturntech's Avatar
saturntech saturntech is offline
There is a resister above the left front wheel towards the bumper on the frame, they always crack, that is probably where you problem is.
