Old 02-04-2009, 06:05 PM
vrl vrl is offline
2004 silverado 4wd
2004 silverado z71,4wd selector switch in dash,lights dont work to indicate 2 or 4wd,any ideas,replaced selector switch,same problem,thanks
Old 02-04-2009, 06:49 PM
j cAT j cAT is offline
Re: 2004 silverado 4wd
does the vehicle go into 4wd ? these are the indicator lights.
Old 02-04-2009, 07:45 PM
vrl vrl is offline
no,alll fuses check good.
Old 02-04-2009, 08:24 PM
jyount jyount is offline
look for pinouts or bad connections to the transfer case control module. If I remember right it is up under the dash about center of the truck. It is not very big at all, think like 1/4 or less the size of the ecm.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 02-04-2009, 08:33 PM
sorry, edit doesn't seem to work for me. Check for 12v to the module, also check for ground. If no lights at all you don't have power or ground to the module, or the module itself might be bad...
Current job: RN
Wife's
Old 02-05-2009, 09:24 AM
so your problem is no 4x4...you are now in 2wd...and the select switch lamps don't light /flash...
check all connections connectors ,,,the ATC control module is behind the headlight switch...check the ground connection here also...
with a meter check for ATC fuse 20A /ATC fuse 2 20A to be good and voltage..
if you cannot find anything it is best to get the DTC for the drive train this means you will need a code scanner that can read THESE codes not ALL do...
report how you made out...
