Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 02-04-2009, 08:01 AM
34Ford's Avatar
34Ford 34Ford is offline
Rear door glass pulley destroyed
The wifes '01 right rear door window fell so I took off the panel to find the plastic pulley had cracked and let the cable fall out.
I took all of the inner frame, motor and cable completely out and for a temp solution to keep the glass up I used a piece of wood and two clamps.
Anyone have a spare door thats maybe beat up but has good guts you may want to sell?
Dennis
2003 Mach 1
2008 Expedition King Ranch 4x4
2010 Taurus Limited
Old 02-04-2009, 04:22 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: Rear door glass pulley destroyed
You probably realize this, but you can pick up a new regulator from various online OEM parts stores which will come with the pulley, cable, motor, and track.
-Rod
Old 02-06-2009, 12:23 PM
34Ford's Avatar
Thanks again Rod.
I hope these guys are legit.
http://www.upanddownmainstreet.com/lincolnLSRight.html
Dennis
2003 Mach 1
2010 Taurus Limited
Old 02-06-2009, 12:36 PM
shorod's Avatar
SHO No Mo
You might try Fast Parts Network as it appears their price might be a bit better and I can vouch that they are legit. I'm not sure why the difference in prices though.
-Rod
Old 02-06-2009, 05:10 PM
34Ford's Avatar
Thats strange. One is $28 and the other is $95
The $95 has a $30 core price. I understand what a core is but why would you want to go thru the hassle if you can buy one outright for $27?
Dennis
2003 Mach 1
2010 Taurus Limited
Old 02-06-2009, 08:09 PM
34Ford's Avatar
Oh, I bet the cheap one is without the motor.
Dennis
2003 Mach 1
2010 Taurus Limited
Old 02-06-2009, 09:26 PM
shorod's Avatar
SHO No Mo
Well, it still shows Item 4 as including Item 5 (motor). It appears to be the whole assembly. Looks like it would be worth an inquiry to Mr. McPhail. Even if it is just the regulator without the motor, chances are pretty good your motor is still okay.
-Rod
Old 02-07-2009, 02:41 PM
34Ford's Avatar
Well even after emailing him twice Im still confused. What a website.
At least the place I linked to shows you a good photo of what you get.
Dennis
2003 Mach 1
2010 Taurus Limited
Old 02-07-2009, 04:16 PM
shorod's Avatar
SHO No Mo
What did Torrie say? All I can say is I've been very pleased with my transactions with Torrie. I've not used the link you provided, but that's not necessarily a good reason not to give them a chance. If you go with Up and Down, please post back and let us know how the experience went.
-Rod
Old 02-18-2009, 05:11 PM
34Ford's Avatar
Received the regulator from upanddownmainstreet and its all back togeather.
Saved a bunch over a dealer install.
Dennis
2003 Mach 1
2010 Taurus Limited
Old 02-18-2009, 07:47 PM
shorod's Avatar
SHO No Mo
Thanks for the update, it's good to have another LS parts source.
-Rod
