Go Back   Automotive Forums Car Chat > Auto Collision Network
Auto Collision Network The forum for Automotive and Collision repair schools, instructors, teachers and individuals in the industry helping to produced better qualified employees. In association with A.D.Smith NACAT, CRIN, ASA.
Old 02-03-2009, 11:51 PM
ppdl23 ppdl23 is offline
Painting over Laquer?
Hi I have a 1960 Ford F100 with the original paint. I think Laquer was used back then but I'm not sure. If it is Laquer how can I tell and will a high build primer adhere to the laquer. Thanks for any help, Peace.
Old 02-04-2009, 06:07 AM
LearnAutoBody's Avatar
LearnAutoBody LearnAutoBody is offline
Auto Body Mod
Re: Painting over Laquer?
One way to determine if it is lacquer is to take lacquer thinner and rub the surface. If paint transfers to the rag, it is probably lacquer. You should be able to apply 2K primer over properly prepared lacquer. You run into problems when trying to apply lacquer over other types of coatings. If you're just needing to seal the sanded lacquer before painting, you may consider using epoxy. Spray two coats as a sealer, then top coat.
Hope this helps.
Check out our class blog
www.BCRN.BlogSpot.com
Old 02-05-2009, 10:58 AM
Oswalds Oswalds is offline
Hope this helps.
NIce Information dude!!!
This is very good suggestion for other users....
Thanks for sharing this information with us ......
Thanks once again.....
_______________________
Renew Touch up
