Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 02-03-2009, 06:47 PM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
94 Camaro 3.4L starting problem
I am working on a 94 Camaro 3.4L i replaced the head gaskets on this car about 3 months ago or so. Well he took a trip about 2 weeks ago and we got hit with alot of snow and got stuck a couple times (no big deal) so he parked the car for a couple days and drove his other vehicle. Well it sat for 2 days and he went to use it but it woudln't start so I went over and looked at it and I could not get it to start, I checked, fule pressure - 46 psi (not sure what is suppose to be but this should be sufficient enough to start), checked spark - good, checked compression on 5 cylinders - good. I have no idea what it could be any help would be greatly appreciated.
Thanks
Joe
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 02-21-2009, 07:36 PM
Re: 94 Camaro 3.4L starting problem
sorry it is actually a 1995 Chevy Camaro 3.4L. Any Ideas????
Old 02-21-2009, 09:44 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
Since you're getting fuel readings and confirm spark, I assume it turns over, just won't catch?
Old 02-22-2009, 05:58 AM
Yes, it turns over just won't start - I am at a loss.
Old 02-23-2009, 09:11 AM
wrightz28's Avatar
Is the security light flashing?
Old 02-23-2009, 08:07 PM
I didn't notice but I asked him and he said NO The SECURITY LIGHT does not flash just comes on then goes off
Old 02-23-2009, 11:22 PM
discnik discnik is offline
Have you checked to see if there is voltage at the injector connectors using a noid light or I think a "194" or "197" bulb by straightening out the fillament wires ?
Have you tried spraying starting fluid in the throttle ?
Is it an orange, weak, or blue/white, strong, spark ?
Just a few thoughts
