Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 02-02-2009, 08:25 PM
4g63gst20 4g63gst20 is offline
Send a message via MSN to 4g63gst20
stroker question.
Hi again everybody, I cant remeber if i ever posted what happened to my car but just to make a long story short:
The car had low oil and i floored it and spun a bearing, the block is junk but i happened to find another 7bolt block to use as a core for $25.
So now i'm debating. Here are my 2 options i've been thinking lately.
1. rebuild with this http://www.maperformance.com/maperfo...k-stage-1.html and still have nightmares about the C word. Im not planning on making more than 300HP.
2. Is a stroker kit, it's a 2.4 with good pistons and rods, i would only need to have my block machined and assembled. here is the link http://www.maperformance.com/maperfo...lding-kit.html
Now IF i went with the 2nd option, i'd just keep the boost low because i'm sure the evo 3 16g i have will be out of breath by 5k rpms. would the 16g survive about 11psi(stock) untill i can afford a bigger turbo and more fuel or would it be enough for about 300-320HP?
I know web sites list the turbo at 380HP
-MODS-
Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/
1/4 mile=14.3@103MPH
Old 02-03-2009, 08:15 PM
NOFX0617's Avatar
NOFX0617 NOFX0617 is offline
Send a message via AIM to NOFX0617
Re: stroker question.
As a C word victim myself, I would say if you are going to spend the money now on a nice rebuild, you may as well find yourself a 6 bolt block. You can get them decently cheap. It may be that little extra now, but its better to spend it now and not have to worry about the good old c-walk at all.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
Walbro 255 fuel pump
GReddy Type S BOV
Turbo XS Boost Controller
Balance Shaft Elimininator
ACT 2600
RRE 11lb No Name Flywheel
Prothane Motor Mounts
Tokico Illuminas Advanced Handling Kit
RRE Front and Rear strut tower bars
RMDSM Front and Rear Sway Bars
TRE Stage 2 Tranny
ARP Head Studs, Main Studs, Rod bolts
Old 02-03-2009, 09:52 PM
yes i REALLY want a 6bolt but i'd hate to spend extra money on DSMlink, I heard that it's REQUIRED to take care of random misfires. I plan on making no more than 300HP.
I have all the supportive mods and i considered the 2.4l because i read that a 2.4l practically cures crankwalk but i'd have to research again. I plan on finishing this by mid-june so i have time to think about it and reasearch.
-MODS-
Old 02-03-2009, 11:46 PM
Thor06's Avatar
Thor06 Thor06 is offline
Jizzed In My Pants
If you're only going for 300 hp or less, dont even bother with the 2.4. If you cant go 6 bolt, then just get a 2.0 7 bolt. I honestly dont think you'll need link to do the 6 bolt swap, but at 300 hp you shouldnt worry too much about CW anyway.
Build on hold until I get a good paying job, either in school or once I get out. At that time a full tear down and complete rebuild should be in order.
The Purple People Eater will ride again... January 2011 can't come soon enough.
Old 02-04-2009, 08:20 AM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
I've never heard of a 2.4l crankwalking, but then again, you dont hear of many people running them. I run one with a heavy clutch and havent had any problems yet.
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 02-04-2009, 12:50 PM
Thor06's Avatar
Jizzed In My Pants
Oh, Longemoco, you know the other thing you should do is check with Steve Hill about him rebuilding you a motor. If memory serves he would do it for like a grand, but I haven't been on style for years.
Old 02-04-2009, 05:59 PM
hey vanila, is your the 4g64 or 4g63 block? if i ended up with the 2.4l then i'd for sure jump to the scm50 from PTE in the future.
Dustin: I allready asked him, he said he doesnt do it anymore because when he used to charge 1k he wouldnt make any money. And i actually bought my core from him for for $25. He is a good guy.
-MODS-
Old 02-05-2009, 07:48 PM
NOFX0617's Avatar
I did not have close to 300 hp and my motor still CW'd. You do not need link for the 6 bolt swap. I do not have it and have not had a single problem with the misfires.
1998 Eclipse GSX
6 Bolt swap
MHI Big 16g
FP Race Manifold
Apex'i N1 Cat-back
Apex'i N1 Downpipe
GReddy Type S BOV
ACT 2600
TRE Stage 2 Tranny
Old 02-08-2009, 02:20 AM
kjewer1 kjewer1 is offline
AF - Advisor
95% of people will get Random Misfired into oblivion without DSMlink, consider yourself one of the lucky ones and don't let it interfere with your ability to give good advice.
A 16g on a stroker will go all the way to redline, but it will only hold 16 psi or so IIRC. Not that that's a bad thing. And it will spool at like 6 rpm, if that's what you're into. It would be ridiculously easy to hit 300 hp on a stroker, but don't forget that you'll need 300 hp worth of fuel regardless of the fact that you make it at less boost pressure. The 510s are too small.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
